Brass or steel?..which ones! and why?
Old Mar 20, 2002 | 09:05 PM
RICHRAD's Avatar
I've removed my smog pump system today. .Brackets and all ,must be 20lbs. at least. Well been searching the archives and just not sure on what plugs(8 of'em) to use in place of the air manifold holes....anyone?
Old Mar 20, 2002 | 09:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It really makes no difference, as long as you never plan to remove them, AntiSieze may help on the steel/iron plugs when you go to take them off...brass will come off with no problem without the A-S.
If you had headers, then brass or SS would be better than one's that rust. SS would still require A-S though.
Old Mar 21, 2002 | 05:30 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Don't use brass, I have had them soften and pop out from the exhaust heat.
Old Mar 21, 2002 | 09:24 PM
RICHRAD's Avatar
I guess I'll be going with the steel ones then. Don't plan on putting the setup back on there anyways. Thanks
3rdgenparts
May 21, 2016 11:50 PM
sreZ28
Oct 22, 2015 08:21 AM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
roysatikas
Sep 22, 2015 08:15 PM
