Setting Valve Lash while engine is running.
Old Mar 21, 2002 | 12:38 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
First, you have to back off the nut till you hear a ticking noise (Over the rest of the car noises) Right? Then you tighten it till you don' t hear the noise. After that however, how much are you supposed to tighten it? 1/2 turn? 1/4 turn? Need to make sure I do these right and no go bending rods and such.
Old Mar 21, 2002 | 12:56 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
1/2 I'm told
Old Mar 21, 2002 | 12:58 PM
Sonar_un's Avatar
Car: '86 T/A
yep, read all over the boards, it varied from 1/4 to 1 full turn.. but half seems to be the reccomended, which is exactly what I am going to do
Old Mar 21, 2002 | 01:02 PM
Sonar_un's Avatar
Car: '86 T/A
ok, something must be wrong, I set them to 1/2 after zero lash, and the car wouldn't start. I put them back 1/2 a turn, and the car fired right up.
Well, the car started, but it deffinitely didn't idle well at all.. it was about to die.
Old Mar 21, 2002 | 01:08 PM
Engine: 406
strange.....wish I could tell you what might be wrong, but valve adjustment is NOT my better subject....Check timing ?
Ps.. Hey are those centerlines on your car ? Those wheels are BAD
Old Mar 21, 2002 | 01:11 PM
Engine: 406
just had to break 100 posts.... :lala:
Old Mar 21, 2002 | 01:52 PM
Sonar_un's Avatar
Car: '86 T/A
Well, I figured out what was wrong, I adjusted the preload w/ the car off, and I shoulda done it slowly when the car was on.
Man that passanger side valve cover is a bitch.
Anyway, yes those are centerlines on my car
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
