Car almost dies at WOT..please help quick!!
Old Mar 22, 2002 | 01:44 PM
BAK12484's Avatar
... Ok i was coming home from school today and when i stepped on it the car didn't accelerate at all but began shaking back and forth, w/ the tach jumping all over. I let off the accelerator until it stopped and then gently eased the accelerator and managed to get the car home (stalled a few times when i had to stop..)
I looked the car over and noticed that the gas cap wasn't on properly and there had been some gas that spilled over.... I put the cap on properly, started her up again, ran her around the block w/ the same damn problems. The car will run fine w/ normal accelerating, but when i get on it a little bit more (around 3/4 throttle) it'll shake
Just an idea, but could air have gotten sucked into the gas tank, so when i go WOT it gets fuel starvation??? Anyone know what the hell else this could be??
EDIT: Forgot to mention that the car ran fine before i filled it up last night
Old Mar 22, 2002 | 04:05 PM
ThirdGen Stoner's Avatar
Is it carbed? If it is then it is a possibility that there is some trash in it. Sometimes you get some dirty gas at the pumps...
Old Mar 22, 2002 | 09:39 PM
BAK12484's Avatar
no its TBI.... im changing the fuel filter tomorrow too.
The damn thing did it again on the way home from work (stalled when i was turning on a main road ) I'd be cruising at around 50mph and the thing would just start shaking, and i did notice popping from underneath the car... so I'm thinking that it could be engine misfire?? I'll be checking out the plugs, wires, cap, and rotor tomorrow to see if its anything
but in the mean time, anybody else have any suggestions??
TIA
Old Mar 22, 2002 | 10:50 PM
topdown's Avatar
Your catalytic converter could be clogged. You should be able to see it glow red after driving if it's clogged that bad.
Old Mar 22, 2002 | 10:55 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Sounds like detonation. Dont understand how that would be caused just by filling up the tank though.
Old Mar 22, 2002 | 11:09 PM
topdown's Avatar
If it doesn't have detonation it wouldn't even run. Premature detonation would cause an audible pinging and would cause the engine to shake. The engine is shaking do to a miss caused by ??? ... I still think the cat is to blame though!
Old Mar 22, 2002 | 11:11 PM
topdown's Avatar
sorry...typo correction...Premature detonation WOULDN'T cause the engine to shake. I gotta watch what I'm doing
Old Mar 23, 2002 | 07:46 AM
BAK12484's Avatar
thats another thing i was thinking, but last night after i got home from work i took a peek under the car and all looked normal.... then again it was only a 3 mile drive. I'll see if i can get the cat off to look at it and see whats goin on because the shaking doesnt happen every time i go WOT - theres the occasional few times when it takes off like normal, making me thing everything is fine and dandy, then the b*tch shakes again
Thanks again everyone for all the help, i appreciate it
Old Mar 23, 2002 | 09:23 AM
topdown's Avatar
If it's intermittent it might be an ignition issue. Cap/Rotor/Wires/Plugs would be some areas to check. Also the pickup coil in the distributer could be throwing fits. It's a cheap part, but the distrubuter needs to be removed and disassembled.
Old Mar 23, 2002 | 03:16 PM
Chevy83Z28's Avatar
Could it be a possible vacuum leak?
Old Mar 29, 2002 | 10:26 AM
dana mickelson's Avatar
im feeling your agony
Im having the same problem, Ihave a 89 rs 305 tbi, Ijust purchased with same prob someone before me has replaced every sensor and most of the fuel line still the problem exsists diagnostics code came up with lean fuel mixture and ive tried a few things but am still lost if you find problem let me know
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
