Got the Ford 9
Got the Ford 9
Ford 9 axle housing arrived today, got it threw the barter system. 41" flange to flange, now have to figure how to mount it in 87 Camaro, spring perches, shocks, etc. Not a 4 link but got the complete SSM kit. Lift bars, crossmember and connectors. Anyone ever "tubbed" a f-body? will have to open up the lift bars to fit this big axle. What the hell have I gotten into...lol
Bob
Bob
never did it, but always wanted to. i'd build a jig around the 10 bolt, get some referance measurements, then cut all the brackets and hangers off the 10 bolt and transfer to the ford rear.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I put a 9" under my car over the winter. Moving all the brackets wasn't that hard. Measure at least 3 times before cutting off the old brackets. I didn't have to worry about a torque arm mount since I went with ladders bars. The ladder bar mounts needed to be enlarged to fit over the 9" tube.
I'm using a big bearing housing with ford backing plates and brakes. I ordered some aftermarket 31 spline axles with ford bolt pattern. My rims have dual bolt pattern so they bolt right up.
I picked up a center section locally with 4.56 gears and a spool.
Full tubbing a third gen is a big job. You're best to take it to someone who knows what they're doing. It's not a job for a backyard mechanic. Mini-tubbing is almost impossible. The "frame" is already too wide. The only area that can be sectioned is removing the bump stop and cutting a bit at the front of the wheel well for larger tires. You can't actually make the wheel tub any wider than it already is without completely backhalving the car.
Car: 87 IROC L98
There are some pics on the web somewhere of a backhalf of a 4th gen. Cut out the entire floor and subframe behind the driver seat to the rear of the car. Weld in a new subframe. Recover the floor with new sheetmetal and tubs. Not an easy job.
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
