If screw in studs and guideplates installed on vortecs..are self alighning RR needed?
Old Mar 23, 2002 | 11:30 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Would self aligning rockers still be needed now that I'm having screw-in studs and valve guides installed?
Old Mar 23, 2002 | 11:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
nope
Old Mar 24, 2002 | 03:02 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Originally posted by Mkos1980
nope
Like he said, nope. The guideplates do exactly what their name implies - they guide the pushrod. They keep the pushrod from having too much movement which, in turn, would give the rocker arm too much movement to the point that it could move off the valve stem. Not exactly an ideal situation if that happens. So guideplates basically keep the rocker arm in place on the valve stem. That is the same task that self aligning rockers perform except they do it with small ridges on the edges of the rocker or washer-type plates on the ends of the rollers on roller tipped ones. One system will be fine on its own and in some situations running both SA rockers and guideplates will create bind and cause valvetrain component failure(s).
Hope that helps,
Matt
italiano67
Dec 11, 2016 09:21 AM
IROCZ1989
Jan 24, 2016 03:55 PM
camaro71633
Sep 1, 2015 10:24 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
GEmrsn
Aug 8, 2015 03:15 PM
