Compression Ratio
Old Mar 24, 2002 | 02:39 PM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
Compression Ratio
Can someone please explain the concept of a compression ratio. Like in the late 60's didnt they run a 13:1 c/p and like now cars run a 9:1. Does the compression ratio reflect apon horsepower. If so how would a person go about increasing a compression ratio? Thanks for your time.
Old Mar 24, 2002 | 02:55 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
compression ratio will help build power by making more cyl pressure
the more pressure that is in the cyl at the time the piston is heading down on the power stroke the stronger and faster it will push down the piston
now ways you can get more compression?
using a thin head gasket
using heads with a smaller combustion chamber
dome pistons.
you can also mill the head
only thing is with more compression it will make you need to either run with better gas, or reduce timing.
Old Mar 24, 2002 | 03:00 PM
Luther6704's Avatar
Car: 1986 Iroc
reduce timing of what? like camshaft or ignition? and thanks for the info, that helped me out a lot.
Old Mar 24, 2002 | 03:25 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
that would be ignition timing
but that is only if you want to use cheap gas
best thing to do is just go buy the lowest grade gas you can without running into ping
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
