Newer head compatibility on '86 intake manifold??
Old Mar 24, 2002 | 07:15 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I have an '86 IROC TPI with the 5.0L. I'm looking to build a 350 for it and would like to go with an '87 up block and heads. Will the newer heads bolt right up to my intake manifold or will some bolt holes or anything need to be ground out? I do know of someone who came across this problem, but it was on a truck, not a camaro. So are all the TPI manifold bases the same or were they different for those early years?
Old Mar 24, 2002 | 07:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TPI bases were different in '85 & '86 vs. '87-later. The center two bolts angle on each side is the issue, and a little elongation of the manifold will allow the bolts to fit the later heads.
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
