Two Q's...One about FP and the other about TV Cable
Old Mar 25, 2002 | 11:39 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
1) When I set the fuel pressure should I disconnect the vac line that goes to the regulator? When I initially did this I didn't disconnect it and I just set it at 48 or 49psi.
2) I have a new TV cable that I just installed and it's too long I think. Which direction to you move the casing to make it tighter? Please tell me it's forward. I haven't been home again to try, but for some reason I think it's backwards for tighter and it's all the way back already. I have a Super Ram and thought I remembered other people with this problem?
Old Mar 27, 2002 | 11:17 AM
Car: 89 IROC-Z
Engine: 383
3 days and no replies? Come on ...help me out here.
Old Mar 27, 2002 | 12:47 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I'll try to help....
1 I've never set the fuel pressure on a TPI engine, but on the GN the vacuum line does need to be disconnected. The vacuum will pull the pressure down about between 5-10lbs.
2 I'm kinda confused on what you're asking but for what its worth moving the cable towards the firewall tightens it (firmer shifts).
HTH's
Old Mar 27, 2002 | 04:46 PM
Car: 89 IROC-Z
Engine: 383
Ok well that takes care of the fuel pressure issue, but does anyone have a clue about the TV cable being too long?
Old Mar 30, 2002 | 07:12 PM
Car: 89 IROC-Z
Engine: 383
Are you telling me that nobody else has had this problem?
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
