Screw in rocker studs for Vortec heads
Old Mar 26, 2002 | 12:57 AM
b91z28's Avatar
Car: '91 Camaro Z28
Engine: 5.7L
Just wondering which rocker studs you guys went with. I plan to be running 1.5:1 self aligning narrow body roller rockers. I belive part number 12371058 (GMPP) is the correct part, but wanted to ask around before buying. This is the same rocker stud used on the LT1/4 engines. Also is there anything special the machine shop needs to know about installing these? For instance, are they shorter scince they are for use without guide plates? If they are shorter does the rocker stud boss get machined down as far as for standard screw in studs? Any feed back is greatly appreciated.
Thanks, Brandon
Old Mar 26, 2002 | 04:16 AM
ede's Avatar
ede
the machine shop should have all the answers. i use ARP studs and i mill my stud boss .4 and i'd guess all studs are the same
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
