Trick flow heads/cam
Old Mar 26, 2002 | 08:14 PM
91 z28 350's Avatar
Car: 91 Z28
Currently my car has slp 1 3/4 headers flowmaster cat back. Next i want to get slp runners, trick flow heads, and trick flow cam. And eventually i will get a intake base and port my plenum.
23 Degree Heads, 64cc CNC-Profiled Chamber
TFS-30400005-CNC Heads for 1987-95 350 non-LT1 with 1.25 in. single valve springs, pair
TFS-30400006-CNC Heads for 1987-95 350 non-LT1 with 1.47 in. single valve springs, pair
Trick Flow Track Heat Hydraulic Flat Tappet Cam and Lifter Kits
TFS-K31401000 266 intake/272 exhaust degrees advertised duration, flat tappet camshaft
TFS-K31401001 284 intake/290 exhaust degrees advertised duration, flat tappet camshaft
TFS-K31401002 308 intake/316 exhaust degrees advertised duration, flat tappet camshaft
Trick Flow Track Heat Hydraulic Roller Camshafts
TFS-31402000 270 intake/276 exhaust degrees advertised duration, roller camshaft
TFS-31402001 292 intake/296 exhaust degrees advertised duration, roller camshaft
TFS-31402002 308 intake/316 exhaust degrees advertised duration, roller camshaft
Out of these 2 heads and these cams what would be the best for what i have ??
Would this give me alot/decent amount of power ?
Is there anything else i should/have to buy for this
Is this going to be worth it or should i save my money ?
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
RS Reaper
Sep 27, 2015 07:04 PM
