Coil Question
Old Mar 27, 2002 | 01:09 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
Coil Question
I am getting ready to do a tuneup to my 91 formula 5.7L, the first since I bought it. After reading a lot on this webstite I have decided to put on the following
MSD rotor and cap
MSD Blaster coil
MSD 8mm wires, blue (the 8.5mm red are twice as expensive, maybe next time)
NGK plugs
I have a question about the coil. There is a blaster 2 coil, for use with 6 series MSD ignitions, and a blaster GM coil that is supposed to be a direct bolton replacement. Which one do you guys use? Can I use either? Which one should I use?
Also I would apreciate any experience yall have had with this equipment.
Old Mar 27, 2002 | 01:22 PM
mattRS's Avatar
the blaster 2 coil has different terminals, so if your ignition is just going to have what you listed, you have to go with a GM coil. i got one from summit a few months back. took me about 5 minutes to put on, no prob at all.
Old Mar 27, 2002 | 01:25 PM
Car: '91 Formula
cool
Thats what I thought. I am not going to change the ignition now to a MSD 6a. They are expensive and I heard they don't really help unless you have like 450 hp or something. Thanks
Old Mar 27, 2002 | 05:54 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the Blaster GM Coil.
Plugged right in.
Need to use the old coil's bracket to mount it.
MSD#8226
-Rich-
lt1z350
Aug 28, 2015 05:57 AM
TheExaminer
Aug 25, 2015 07:34 PM
Bryan F
Aug 18, 2015 02:28 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
redmaroz
Aug 16, 2015 11:40 PM
