WTF 8.23 at 94.7 MPH in the 1/8th?
Old Mar 28, 2002 | 11:14 AM
Brandog87GTA's Avatar
With that MPH shouldnt I be running a LOT faster than that?? I was running on street tires and hosing it during second gear. I was expecting 7's easy. My 60 ft was 2.3? What should I be running with that MPH?
Old Mar 28, 2002 | 11:47 AM
Vader's Avatar
That should give you at WORST a 12.98 S ¼ mile time, and that's IF you don't increase velocity during the second half of the ¼. What's the complaint? Other than the longer 60' times (probably traction issues) the time seems pretty good for a heavier car.
Old Mar 28, 2002 | 12:17 PM
ede's Avatar
ede
your 60' suck, get them under 2.0 and you'll see big et reduction
Old Mar 28, 2002 | 12:56 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the rpm cam is not really designed for your gears
I would b pretty satisfied with those heads and other parts. Your probably near 400hp.. but you can't use all of it without gears.
Old Mar 28, 2002 | 01:08 PM
What gear would u suggest. I have 3.27 in it right now. Only thing I hate is the borg warner gear prices.
Old Mar 28, 2002 | 02:24 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
slicks and 3.73 or 4.10 gears would do you good
Old Mar 28, 2002 | 03:50 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The 2.3 60ft is killing you. Last fall I went 7.76 at 94 with a 1.72 60ft. Here's the video www.koolmeister.com/776b.mpg
Unfortunately not much can be done about the price of the 9 bolt gears and posi carriers unless lots of people start buying them. Low volume = higher price Unfortunately it's just Econ 101 On the bright side, atleast ratios up to 4.10 are now available
Miles
www.9bolt.com
Old Mar 28, 2002 | 03:59 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
if you really want good 1/8 mile, the 4.10s
but.. 3.73s will be the best all around gear I would think.
Old Mar 28, 2002 | 05:52 PM
JAY87GTA's Avatar
To hell with gears, that'll just make your traction issues worse. Do some work on the suspension and get you 60' times down to 2.0 on the street tires. LCA's and a LCA relocater would be a good first step.
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
gt4373
Oct 8, 2015 10:37 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
