Will 1.6 rr's bind the valve springs on AFR heads?
Old Mar 28, 2002 | 05:50 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Max gross lift on the ZZ-9 camshaft is .520 on the exhaust lobe. Will the valve springs on AFR 190's part #1018 bind if I use 1.6 roller rockers? Thanks.
Old Mar 28, 2002 | 05:55 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
The 1.6 would make your total lift .550 they always ad .030 lift. AFR could tell you if you give them a call.........be careful I have killed a set of spring that way.....
Brian
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
