Air/Fuel ratio question... best ratio
Old Mar 28, 2002 | 02:41 PM
ORAY777's Avatar
Whats the best air/fuel ratio at WOT? Is there a way to check this value while driving at wide-open throttle. I know they sale air/fuel ratio gauges. Anyone have any insight to this. Thanks.
Old Mar 28, 2002 | 02:47 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
wish it where that easy
what a/f ratio you want to run depends on what your setup is
Old Mar 28, 2002 | 03:57 PM
Z28DJP1987's Avatar
I am running a 13.1 a/f ratio @ 41/42 fuel pressure on my 350, if this helps. Results from a Dyno Run.
Old Mar 28, 2002 | 06:55 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
the only way to tell for sure what your best a/f is would be to use a dyno
cause some setups like to have a richer mixture while others need something a little bit lean
Old Mar 28, 2002 | 10:26 PM
daverr's Avatar
plugs
why dont u check the plugs it`s way cheaper than chasis dyno.For example make a run down the quarter mile ,then stop at the pits pull some sparkplugs.check the color ,dark =rich white=lean ,u want light brownish color(not too light not too dark).
InfernalVortex
Apr 20, 2021 11:31 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
