Hesitation at low speeds
Old Mar 28, 2002 | 04:26 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
Had problems with major hesitation and chugging. Replaced plugs, wires, fuel filter, MAF sensor, O2 sensor, intake manifold gaskets, all vacuum tubes, PCV valve, cleaned throttle body and injectors. Had a major chugging problem and pushed one of the wires on top of one of the injectors and it 'clicked' and it didn't chug that bad anymore. Still have a slight chugging problem though. Before i replaced the MAF sensor, i got error codes 34, 42, and 44. Haven't had a chance to check yet. Like i said, it says it's running lean, but i already replaced the O2 sensor! PLEASE HELP!!!!!
Old Mar 29, 2002 | 01:19 PM
GTA88's Avatar
Did you check the wires going to the other injectors ? Also, are all the plug wires on tightly ?
Old Mar 29, 2002 | 02:04 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
Hesitation
Yeah, i replaced all the wires and put them on tightly and made sure all the wries to the fuel injectors were on tight. I can't seem to find any vacuum leak anywhere either. Thanks for the reply, any other suggestions?
Old Mar 29, 2002 | 02:05 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
Oh yeah, i disconnected the battery and reconnected it and ran the code checking and i have no errors it says.
Old Mar 29, 2002 | 02:06 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
If your getting all those codes, I would try the cap, rotor, and ignition controll module. Had the same problem on my friends GTA, turned out to be the ICM.
Old Mar 30, 2002 | 11:50 AM
TrnsmGTA's Avatar
Car: 87 Trans Am
I'm not getting any codes anymore, but it still runs funny. Like when you give it a little gas, just slightly pressing on the pedal at any speed really it kinda chugs a little.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Thornburg
Aug 27, 2015 08:28 PM
perZ
Aug 15, 2015 01:17 PM
novaderrik
Aug 10, 2015 12:44 PM
