Can anyone tell me what's wrong with the 2.8 v-6 in my friend's camaro?
Old Mar 30, 2002 | 08:25 PM
firebird305's Avatar
My friend has either a 85 - 86 camaro with the 2.8 fuel injected v-6 If someone is standing in front of the throttle body spraying starter fluid into it it will run,but as soon as you stop it shuts off.Does anyone know what's wrong with the engine and what can be done to fix it?
Old Mar 30, 2002 | 08:35 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
sounds like the fuel pump to me.. Do you hear the fp turn on ( short buzz or hum when you turn the key on?
Old Mar 30, 2002 | 08:42 PM
He just replaced the fuel pump, you can here the fuel pump start up when you first turn the key.
Old Mar 30, 2002 | 08:46 PM
Engine: 406
beyond me Sure someone else will help ya though..Not much up on F.I. sorry.
Old Mar 30, 2002 | 09:34 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
i would check to see if you got fuel pressure. the pump can still run, but not be pumping any fuel. had this happen to me when i owned a 2.8l camaro. hope this helps
Old Mar 30, 2002 | 10:49 PM
88camaro_SC's Avatar
i would check the fuel filter or test the pump.....
evilstuie
Jan 9, 2020 08:29 PM
Reborn756
Sep 4, 2015 03:42 AM
Linson
Aug 21, 2015 02:12 PM
Cripley
Aug 17, 2015 03:35 PM
sonu1975
Aug 11, 2015 08:38 AM
