Sluggish and rich???? H E L P
Old Mar 31, 2002 | 04:10 PM
craiger's Avatar
What could be causing me to run so rich? I can see raw fuel comming out of the exhaust at idle and when i rev it up? My fuel psi is at 43 and i have my chip burnned so my BLM's are between 126-132 at part throttle which is almost perfect AF ratio. Timming is at 6deg advanced and vacume is a steady 16 at idle? No codes..an occasional egr code, but that is a very tempramental code from what I have read. I have a new engine with AFR heads, sllightly larger cam and it seems very sluggish. Plugwires and plugs are good. Plugs under inspection at teh track show a rich condition?
Can anyone help??
I plan to check the coil
put new plentum gaskets on >>>>no leaking via the carb cleaner test and vacume gauge.
check all the plugs after a run down the street
Old Mar 31, 2002 | 10:15 PM
craiger's Avatar
ANYBODY?
Old Mar 31, 2002 | 10:19 PM
rhuarc30's Avatar
What do you mean you can see raw fuel? Is it dripping out, black smoke, or what?
Old Mar 31, 2002 | 10:47 PM
craiger's Avatar
it's not smoking at idle, just dripping. But at the end of the track it is black smoke? I suspected tps bad, but the voltage is with in normal range. Fuel psi is stock, new 02 sensor???
antman89iroc
36
Jan 31, 2016 08:42 AM
sac92transam
Oct 7, 2015 02:31 PM
Luigytico09
Oct 1, 2015 08:46 AM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
