Just got my car out of storage and...
Old Apr 1, 2002 | 03:57 PM
dans87ta's Avatar
Car: 87 trans am, 93 full size blazer
Engine: 5.0, 5.7
Transmission: A4
I go to get the oil changed at wonderlube, where you sit in the car while its being done, and all I hear is "your oil pan is dented...oil pan leak...oil lines leaking....front main seal leaking....transmission pan leaking.....transmission rear output shaft leaking." AHHHHHHHHHHHHHH. Sorry, had to vent. Then I get everything fixed and I go back to college, and now its snowing here. Damn wisconsin.
Old Apr 1, 2002 | 04:33 PM
rezinn's Avatar
This happened right after you changed to synthetic oil, correct?
Old Apr 1, 2002 | 04:41 PM
dans87ta's Avatar
Engine: 5.0, 5.7
Transmission: A4
yup. I figured it'd be alright, but I guess not. Its only got like 104,000 miles on it. well its fixed for now, but i am getting a new motor anyway, so I just gotta keep tabs on the leaks till then.
Old Apr 1, 2002 | 04:58 PM
rezinn's Avatar
If you're going to buy a new motor, you should just put regular castrol oil into this one. Don't waste money on synthetic anymore if it's going to leak out. I don't know if changing back will help the leaking at all, and it probably won't.
Old Apr 1, 2002 | 05:26 PM
Vader's Avatar
That's O.K. It's snowing here, too. At least there's JJO...
Did you switch to synthetic just before storing it? You probably should have driven the car with the synthetic for a while to soften up the seals and clean out the "crap" that was sealing your engine. I've converted to synthetic on engiens with a lot more miles than that with no real problems.
Old Apr 1, 2002 | 05:41 PM
dans87ta's Avatar
Engine: 5.0, 5.7
Transmission: A4
No, I switched to synthetic last spring, like in may or something. I drove it all summer, then stored it, and it never leaked then. I looked under where I stored the car and didnt see any leaks, and it ran wonderfully everytime I started it up over winter. It was just wierd, cause I didnt expect it at all. The thing that really bothered me was that I drove the car for a week before this, like 200 miles, and it didnt have that much oil in it. We'll see what happens in the future I guess. Now I gotta save up for the new motor.
Old Apr 2, 2002 | 02:38 PM
rezinn's Avatar
I've always thought that synthetic cleaning out the "crap" is actually what causes the leaks on some cars. If you've got a 15 year old gasket on there, that crap is probably what's keeping it from leaking in the first place.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
NBrehm
Aug 5, 2015 07:57 PM
