2 bolt or 4 bolt
Old Apr 2, 2002 | 12:39 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
2 bolt or 4 bolt
Did our birds come with the 2 bolt or 4 bolt mains? Curious cause I just picked up a 4 bolt shortblock 350. If I have a 2 bolt in the 92 I'll be building up this 4 bolt. (383)
Old Apr 2, 2002 | 12:59 PM
sIcK pUpPy's Avatar
We got the two bolt. From what I understand, our blocks can handle quite alot, no real need for a four bolt. Anyone else?
JD
Old Apr 2, 2002 | 01:03 PM
Fast3rdGen's Avatar
i got a 2 bolt block i used for my 383 and it spins to 7500 without breakin a sweat. no real benefit to running a 4bolt. besides...the main webbing is beefier on a 2 bolt block makin it stronger anyways.
Rich
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
That's what I thought.
I'd be building the 4 bolt for 11 sec NA passes.
Old Apr 2, 2002 | 03:44 PM
rhuarc30's Avatar
Well take your 2 bolt block and add the four bolt splayed caps, the conversion works better on a 2 bolt block anyway, and that'll hold just about anything you can throw at it.
Old Apr 2, 2002 | 03:54 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
from what i understand,unless you only do racing or have a high-revving engine,you do not need a 4 bolt block.Same with having forged pistons,etc.You said you are gonna have it run 11's- is it gonna be a street car too?
Old Apr 3, 2002 | 12:00 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Most definitely a street car. There are lots of ricers and rustangs that are begging for a spanking.
I haven't quite decided yet it I want to go forged or hypereutetic pistons. I understand that forged aren't exactly recommended for the street due to the differences in expansion.
rhuarc30 - you say convert my 2 bolt? would that actually be stronger than the factory 4 bolt? I believe this 4 bolt came out of a 93 truck. Higher nickel content
Old Apr 3, 2002 | 12:50 PM
bradkeith's Avatar
Rhuarc30 is correct. A 2 bolt block with the milodon 4 bolt splayed caps is stronger than a factory 4bolt because the outer bolts are farther apart and not stressing the same area.
Old Apr 3, 2002 | 12:56 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I see now. Thanks guys.
Maybe I'll just hang onto the 4 bolt for that kit car I plan on building someday.
Old Apr 3, 2002 | 01:02 PM
rhuarc30's Avatar
Lotsa people run forged pistons on the street, you just gotta be careful with your clearances when you install them. For the kinda power your looking to make I'd go with the forged in case you hit some detonation.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
