vibration
Old Apr 4, 2002 | 09:07 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
vibration
My trans am starts to vibrate at right around 65 mph. I just got new tires today and had them rotated, and it's still doing it. Could it be the U-Joints? It kinda seems like it starts in the front of the car. Any help is appreciated.
Old Apr 5, 2002 | 05:10 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
do you mean you had them balanced? if not, I think you better...
Old Apr 5, 2002 | 04:42 PM
84 t/a 5.0's Avatar
Yeah, I meant balanced.
Old Apr 6, 2002 | 01:26 PM
84 t/a 5.0's Avatar
Can't someone help?
Old Apr 6, 2002 | 02:00 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: vibration
could be a multitude of things. was it vibrating before the new tires? if not, then it is within the tires. if so, then could be tie rods, ball joints, idler arm, shocks, struts, center link, or bushings. would need to get it up in the air and shake things around to find out.
one way to test for u-joints. does happen at a particular rpm? or just at 65mph. get the car to the point where is vibrates. put it in neutral. if the vibration goes away, then it is the u-joints or imbalanced driveshaft. if not, then suspension or tires.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
