Drill heads for roller rockers???
Old Apr 4, 2002 | 10:57 PM
TPortFormula's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: a crappie 700-R4
I just got a set of 1.6 rollers for my car, still stock, and i was wondering if any body out there had to drill their stock heads for 1.6 rollers. its a 91 305, and i really don't feel like drilling my heads. comp cams say some heads may need drilling. does mine? help me out here guys.
Old Apr 4, 2002 | 11:09 PM
oh, and its the TBI cam, so so there's not much lift (TBI to TPI swap, no new cam).
Old Apr 5, 2002 | 04:22 AM
ede's Avatar
ede
drill what for what? there's no reason to drill anything to use roller rockers that i can think of.
Old Apr 5, 2002 | 07:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
On about half of the SBC heads I've ever worked on, the push rod guide slots were not long enough in the direction toward the stud to accomodate 1.6 rockers. The increased ratio is accomplished by making the distance between the push rod seat and teh stud shorter, which moves the push rod inboard. This change in the push rod location is enough that at least one of the holes interferes with the push rod. There's no way to predict what heads will need it; I've seen engines with the OE heads where every single one on one side cleared, and every single one on the other side interfered. It's strictly luck of the draw.
Your car has "self-aligning" rockers, which means that the holes are bigger anyway. You might get lucky.
The issue has nothing to do with rollers, only the ratio change.
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
