Code 34 after winter storage
Car: 87 IROC-Z, 82 Pace Car
My car has been in storage since November 1. I finally was able to pull it out yesterday. It started right up, but it ran rough and kept wanting to stall out. I gave it some gas to keep it going and thru a code 34. I shut off the car and restarted it, no engine light. Before the car went into storage, I filled it up wit 92 octane and used Stabil. Is this normal when the car has been sitting for so long with 6 mos old gas? It appears to be running OK. It was just after initial startup that thru the code. Any info is appreciated.
I think things like stable will help out but they don't always fix things 100% aginst water and things like that... I would run your tank out and fill her up with 92.. After you run a tank or two through it let me know if your still having the problem. You can throw EGR, 02 and a bunch of other things from letting the car sit.. Darn cobwebs get into them, if you know what I mean.
