Timing on 87 Z-28
Old Apr 5, 2002 | 07:52 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Timing on 87 Z-28
Its a carbed 305 Z28 with a external coil dist............When I pull the plug to time it it will die..........then next time it will run......when its running I am only getting 12* of mechanical advance from the module is this correct. The advance is correct when the computer is pluged back in and takes over. I know the base is correct and I am just wondering where the problem may lie with it coming and going. I have the base set a 6* btdc as the car calls for.
Brian Felts
Old Apr 6, 2002 | 09:12 AM
BTT HELP!!!!!!!!!!
Old Apr 6, 2002 | 10:04 AM
sleeper's Avatar
when you say "pull the plug" I assume you mean the vacuum advance hoose?
If it dies right after you disconnect the vacuum advance then I suspect your idle is too low or you have a vacuum leak somewhere else.
Old Apr 6, 2002 | 11:39 AM
No on the external Coil Hei with the Computer Controlles Q-Jet there is no vaccume Advance. The dist Module will take over then you unplug the computer controll from the Dist. thats how you set the base timing. My problem with the base set @ 6* the car will run fine the next time you unplug the controll you may die.
Brian
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
