Comp Cam Selection
Old Apr 6, 2002 | 06:09 PM
fbody dude's Avatar
Car: 92 Camaro
Comp Cam Selection
Hey Everyone,
I am trying to follow the buildup of the 1982 Camaro 305 V8 in the March 1999 Issue of Car Craft. However, I'm trying to build this for my 1992 305 V8. I have some questions about the cam selection. Car craft used XE262H-10 (Specs Below). I emailed Comp Cams for the equivalant cam for my roller setup (Email Message Below). The XR270HR-10 cam they suggest seems to be a little diffrent, is this to compensate for the roller lifters? And, the XR270HR-10 is a RETRO-FIT cam, does this make a difference? Also, The description of both cams says it has a noticeable idle. How noticeable is it? If your on a date at a stop light, will she ask, "What is wrong with your car?"
Thanks,
Jeff
Part Number 12-238-2
Engine 1955-present Chevrolet
262ci-400ci
8cyl.
Grind Number CS XE262H-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.462 0.469
Duration At 0.006 Tappet Lift 262 270
Valve Timing At 0.006
Open Close
Intake 25 57
Exhaust 69 21
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.308 0.313
Lobe Separation 110
Recommended Valve Springs 981-16
>message sent to comp cams
> Dear Compcams,
> I was reading an old issue of Car Craft (March 1999). They had built up a
> 1982 Camaro 305 V8 that made some fairly impressive numbers. I am trying to
> follow their build up with my 1992 Camaro 305 V8, but taking in the
> consideration the ten years of difference in these engines. They used a Comp
> Camshaft part#XE262H-10. Do you have this camshaft in a roller version?
> Also, they used a Comp Cams Magnum Double-Roller Timing Chain. Do you have
> this available for my 92 305 V8?
> Thank You,
> Jeff
>message from comp cams
Jeff, sure we have a roller cam that matches that grind number camshaft and if
you order that in K-kit you will receive a roller timing set also. I have
included the specs below.
Thanks,Hadley@compcams
SPEC CARD INQUIRY
PART NUMBER12-422-8
ENGINE SMALL BLOCK CHEVY 265-400
GRIND # CS XR270HR-10
DESCRIPTION
INT EXH
VALVE ADJUSTMENT HYD HYD0
GROSS VALVE LIFT .495 .502
DURATION AT
.006 TAPPET LIFT 270 276
VALVE TIMING OPEN CLOSE
AT .006 INT 29 61
EXH 72 24
THESE SPECS ARE FOR CAM INSTALLED
AT 106 INT C/L
INT EXH
DUR AT .050 218 224
LOBE LIFT .3300 .3350
LOBE SEPARATION 110.0 INT MASTER ID 3313
ADVANCE 4 EXH MASTER ID 3314
RECOMMENDED CC VALVE SPRINGS 986-16
Old Apr 6, 2002 | 08:24 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the HR270 is just the roller version of the other cam
should work a little better. I would suggest using a 3.42 gear at least.
Old Apr 6, 2002 | 08:55 PM
fbody dude's Avatar
Car: 92 Camaro
I'm not so sure. The specs for each cam is different. The lift on both the intake and exhaust has at least .03 differance between the two. I understand the shapes of each is a little different because one is flat and one is a roller, but shouldn't these numbers be fairly close. Also, the XR270HR-10 beinhg a retrofit bothers me when they have a section on their website that is dedicated to cams for cars that had originally came with a roller cam.
Old Apr 6, 2002 | 09:25 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
a flat tappet cannot generate the lift the roller can with the same duration
its got more lift bc it can be opened faster.
the prefix determine the grind type. 12s are for retro fit and 08s are for oem rollers.
You should actually order the 08-422-8
Old Apr 6, 2002 | 09:31 PM
iroc22's Avatar
Dont get the retrofit cam because you can just get the 87-95 roller cam and it fits perfectly. Those are the same cams, its just the roller can have more lift because of the faster ramp speeds and more lift=more power. Dont forget to look at Comp's lineup of TPI camshafts. That's what I got.
Old Apr 6, 2002 | 09:33 PM
iroc22's Avatar
Oh and what have you done to your 305 TBI? cause for a fairly stock TBI, thats way too big of a cam.
Old Apr 7, 2002 | 05:38 PM
fbody dude's Avatar
Car: 92 Camaro
Thanks for the information.
Mods:
Gutted Cat, Flowmaster Muffler, Smog Pump Deleted, Adjustable Fuel pressure Regulator, MSD Ignition Coil, MSD Wires, MSD 6A box, Accel Cap, Lower Thermostat, Hypertech Chip, Fan Switch, K&N Filter, Silencer Ring Removed, Cold Air Intake, high volume oil pump
However, right now the engine is farly stock. I was leaning toward that cam for a couple of reasons. One, the car craft issue showed an increase of 41 hp just by switching the cam. Also, I was planing on getting an Edelbrock Performer RPM intake, a set Hooker Long Tube Headers with 3" exhaust, and, if there is still money left in the budget, some heads. Just trying to match the cam to my future plans of the engine. I noticed you have a comp cam, do like it? Is the lobe separation 110* or 112*? That's my big apprehension. I really do like a very smooth idle and the xr270hr-10 specs has it listed as noticeable idle.
I'm still little confused on what to do. The idea of going to a different engine (Lt1 or Ls1) is starting to be more appealing to me, especially after seeing how much the k-kits cost.
After posting this, I started digging around on Comp Cam's website. I found the technical articles about cams in their online catalog. I should have read this first, instead of jumping to cams and trying to figure out what everything meant on my own. For all those that want to know about cams, read it. It's pretty lengthy (I read about 50 pages), but well worth it.
http://www.compcams.com/catalog/
Old Apr 7, 2002 | 10:08 PM
iroc22's Avatar
Well I dont know if you missed my mods, but their in my sig. The duration on the cam is what u need to look at, and with my higher flowing heads, I can run this cam with good results. The LSA on my cam is 112*. I hope you know something about burning chips and winadl cause with that much duration, the computers gonna go nuts. Car Craft was working with a non-computer controlled engine.
P.S. I have the Comp Cams 2001 Catalogue.....
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
masonta
Sep 1, 2015 06:40 PM
