Where can I find some heads and a cam for a good price.
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Looking for a mild cam and some vortechs heads and I'm to lazy to search anywhere else.
Well for now I just want a little more kick then the old stock 305. My real plans are to build a 400 block but I'm not sure if thats going to hold up in my car. Might just break or bend the t-tops with the kinda parts that I want for that. Heads? Cam¿ Price?
Well for now I just want a little more kick then the old stock 305. My real plans are to build a 400 block but I'm not sure if thats going to hold up in my car. Might just break or bend the t-tops with the kinda parts that I want for that. Heads? Cam¿ Price? If you want a GM cam also,www.gmpartsdirect.com
Car: 2006 Silverado 1500
Engine: 5.3L
for your 305tbi i'd recomend looking for an L31, LT4, or LT1 cam and trying to find a set of L98 aluminum or L30 heads (which will require a new gm intake). the only problem is with them heads your not going to have an e.g.r. valve without some work. the only other option is to try to find some world products heads, but i'd recomend checking ebay for a used set for good prices.
