Negative and Positive Backpressure EGR Valves Question within..
Old Apr 8, 2002 | 10:13 PM
ORAY777's Avatar
I have a question probably relates to everyone in here who has ever had to deal with the ever annoying code 32 especially when you have changed your exhaust to a better freeflowing exhaust. I was wondering is it possible to switch from a positive backpressure valve to a negative backpressure valve. I heard that negative backpressure valves were for high performance vehicles with less than normal backpressure. Would this work for our cars. Where can you purchase a negative backpressure valve and what part number would it be. Or better yet what cars did come with the negative backpressure valves? Also is there another way to get rid of this code without really disabling the EGR. I've seen in Mid America a code 32 fix solution but it's only for 85-89 cars. Mine unfortunately is a Speed Density car with MAP Sensor which i think the computer reads vacuum changes with this sensor. Give me some input. Later.
1991 Z28 Camaro 1LE 5.7 auto.
F-bodies Forever!!!!
1992rs/ss
16
Jan 28, 2016 09:58 PM
Out-Cast
Aug 17, 2015 10:57 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
