Wont start? Starter, battery or alarm system?
Old Apr 9, 2002 | 12:16 PM
85wilrocu's Avatar
Took my car for a canyon drive this past weekend, everything was fine. Come monday morning, i get in my car and it won't turn over?? Everything else turns on, the fan, radio, everything? But doesn't crank??
O.k i came to the conclusion that it might be something with the alarm i just had profesionally installed?
I don't really know, and yes i did a search and i'm still stumbed
Old Apr 9, 2002 | 12:40 PM
howsci's Avatar
Check your fuses first, if it's not that then it is possible you have a bad starter or you have a short in the wiring to the starter a bad ground etc. i suppose it shouldn't have anything to with the alarm system but it's possible
Old Apr 9, 2002 | 06:13 PM
85wilrocu's Avatar
TTT, FOR THE NIGHT SHIFT!
Old Apr 9, 2002 | 06:49 PM
86IROC350NY's Avatar
weird fix to your problem
I had the same problem. First turn the key back, then Try opening the door (so the interior light goeson) then turn the key. if nothing happens then open the door and slam it, then try to start it. In my car it may be a loose connection or the key switch. The car was broken into and the steering column had to be replaced.
You can do that until you get the wiring fixed. Let me know what happens.
--Dan
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
