Oil cooler idea
Old Apr 10, 2002 | 10:07 PM
86IROCZ's Avatar
Oil cooler idea
I'm in the process of changing from an auto to a manual. My friend suggested that I use the tranny cooler that's in the radiator as an oil cooler. I think that the lines may be to small inside and cause flow problems. What do you guys think?
:lala:
Old Apr 10, 2002 | 11:06 PM
Vader's Avatar
86IROCZ,
That should work fine if the lines are 5/16" I.D. or larger. That's just about the way the factory oil coolers on Impalas are designed. What size steel lines are on the transmission oil cooler in your radiator (I've never had mine open)?
Old Apr 10, 2002 | 11:32 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you can always snag the oil cooler of a 96-91 RX-7
they have very good oil coolers that I am sure you can mod to hook up to your car
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
