Vacumm question after new motor has been installed.
Ok, this past winter I tore my old 7 cylinder 352 sbc motor out, I rebuilt the motor and made a 383 out of it. I used the same cam, heads(+.100 taller valves and stronger springs, edelbrock 6085 heads), I used the same 1.6 crane roller rockers, longer pushrods(7.300), and the same intake/superram. Should be around 10.0 to 1 compression also.
My question is, at idle my car is at 42-46 kpa, before the teardown i was idling at 55-60kpa steady, now. I know my valves are clicking and need some adjustments but could that be causing my lower vacumm numbers?
Thanks,
Brendan
Thanks,
Brendan
