My gauges are broke!!!!!!!!!!!!!
Old Apr 11, 2002 | 11:33 PM
Tbird's Avatar
I have an 87 camaro z28 and my oil and temp gauges dotn work the temp is maxes out and the oil says zero i think the gas gauge works but its kinda funky. Does anyonek now how i ca fix these or how much new ones are or what the prob could be. Thanks
Old Apr 12, 2002 | 12:27 AM
iroc5speed's Avatar
well, the temp sender is on the driver's side head, you can change that, the oil sender is on the back of the engine just above the intake(usually), you can change that, and the gas sender, well, that one's in the tank, judge gas off of milage.anyways, change those two things and see if that helps, if not then you amy actually have some problems, either with the engine or with your electrical system
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
