Freeze plug
Old Apr 11, 2002 | 06:50 PM
SgtSkip's Avatar
Freeze plug
How do you remove a stuck freeze plug? I've got a 327 with a front freeze plug stuck.
Old Apr 11, 2002 | 07:53 PM
sleeper's Avatar
drill a hole in the middle of it... thread a large, self tapping screw into the hole (or one of those wall anchors with the legs if the hole strips)... then use the closed end of a crowbar under the head of the screw to pry it out.
Old Apr 11, 2002 | 10:56 PM
SgtSkip's Avatar
Thought so. I think I'll have to use a lag bolt. Thanks for the help!
Old Apr 12, 2002 | 12:29 AM
RJR99SS's Avatar
i made my own little tool for that. just got a spade type wedge and rounded the end of a little. then i just hammer the bottom or side of the freeze pluge until it is sitting sideways in the hole. then you can usually just grab them and pull them out, or put a screwdriver under the lip on them and tap them out. its alot easier than drilling....just be sure you dont hammer the plug INTO the hole...
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
