oil pressure drops at 220
Old Apr 12, 2002 | 10:12 AM
blkform88's Avatar
When I get my 305tpi lb9 running at 220 degrees, the oil pressure will drop from 30 to about 15. I had an oil and filter change about a month ago. Has anyone else had this happen? How much of a problem is this?
Old Apr 12, 2002 | 10:13 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It's normal for when the car to heat up oil pressure drops, as the oil gets thinner. As to whether dropping to 15 is good, a good rule of thumb is 10 psi for every 1,000 rpms.
Old Apr 12, 2002 | 02:01 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I would switch to a thicker oil maybe 20w50 for summer time use.
njdaewoo
PS: Check out my Trans am+ Iroc = Tramaro
Old Apr 12, 2002 | 02:51 PM
rezinn's Avatar
If this is at idle, it's not a problem.. although the pressure change should be a gradual fall. If otherwise, your oil pressure sender may be giving you bad readings.
Old Apr 12, 2002 | 03:32 PM
85transamtpi's Avatar
It is normal for oil pressure to drop as your engine temp. rises. Remember that hot cast iron expands.
Your pressure should be fine as long as it goes up with increasing revs.
-Doug
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
