Can Cam be installed without removing engine?
Old Apr 12, 2002 | 11:46 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I have a 1991 TA with 305 TPI and 5 speed. Can I change the cam without removing the engine?
If so, what has to be done?
Thanks.
Old Apr 13, 2002 | 10:13 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The short answer is yes. Do a search in this forum, this Q gets asked about twice a day.
Old Apr 13, 2002 | 10:26 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yep, you'll have to remove everything in front of the engine, and probably rent a harmonic balancer puller, that's what I did.
Old Apr 13, 2002 | 11:52 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
and a timing gear puller as well
Old Apr 13, 2002 | 05:40 PM
Blackened's Avatar
Okay.. WHY do you need a timing gear puller ? He's not changing the timing chain... just the cam!
Old Apr 13, 2002 | 05:44 PM
wasp's Avatar
i believe the timing chain has to come off to pull out the cam? maybe im wrong
Old Apr 13, 2002 | 05:45 PM
wasp's Avatar
oops yeah that gear is held onto the cam with bolts,
Old Apr 13, 2002 | 05:55 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I replaced my cam with the engine in the car. You will need to remove all the accessories, water pump, timing chain cover, cam timing sprocket, harmonic balancer, radiator, metal support thingy in front of the radiator (gets in the way of pulling the cam out), distributor, intake manifold (and everything on top of it), lifters, pushrods, valve covers (to loosen the rockers). I think thats everything.
In short, you will have to tear the engine down to only the block, oil pan, heads and headers.
While you have al lthis apart, I would reccomend reaplcing the timing chain with at least a new one, or an aftermarket double-roller type.
Old Apr 13, 2002 | 06:29 PM
Blackened's Avatar
He has a 91 TA so the accessories can stay in place. ONLY the water pump needs to be removed. Changing the timing chain isnt a bad idea, but it's not necessary unless have an ugodly amount of miles on the engine.
Old Apr 13, 2002 | 06:32 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well on my egnine some of the accessory brackets are in the way of getting the water pump off.
Old Apr 13, 2002 | 08:30 PM
iroc22's Avatar
Change the timing chain...even if its an OE one. The chain streches even if there isnt an ungodly amount of miles on the engine. You'll see the difference in the idle.
Old Apr 13, 2002 | 08:31 PM
iroc22's Avatar
How did you get the cam out with the rad and timing cover in the way?
Old Apr 13, 2002 | 08:47 PM
Car: 99 Formula
Axle/Gears: 342
I totally agree. Eventhought the OE timing chains don't need changed until 150k I believe, it's still a good idea to buy a new one, it will help restore some lost power, plus the fact it's so accessible while changing cams.
Old Apr 13, 2002 | 09:37 PM
iroc22's Avatar
:hail: :hail:
Old Apr 13, 2002 | 09:47 PM
Car: 99 Formula
Axle/Gears: 342
I'm pretty sure he's excluding those, but maybe talking about the alternator and water pump??
If not, I'd like to see how he did that one, unless his last name is Houdini.
Old Apr 13, 2002 | 10:02 PM
Blackened's Avatar
Hellooooo.... I was refering to the accesories that need to be removed. If you really want get smart about it, you CAN remove the cam w/out taking the rad of ever the fans out. Chop it up with a torch... LOL
Old Apr 13, 2002 | 10:12 PM
Car: 99 Formula
Axle/Gears: 342
True, but I'd like to see you slide the new cam in thru the distributor hole lol
Old Apr 13, 2002 | 11:16 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
my engine had 100k on it when i swapped cams and i got a new double roller chain, it had a lot less slack in it than the oe one.
Old Apr 13, 2002 | 11:54 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Thanks for all of the advise.
So for the 305 I won't have to remove all of the top of engine stuff???
Sounds like just everything in the front.
Any reconnendations on a double roller timing chain?
Anything else to change while all of this is appart?? Probably put a new waterpump on too.
Thanks again.
Old Apr 14, 2002 | 12:05 AM
Car: 99 Formula
Axle/Gears: 342
You have to remove the whole top half, intake, carb/tpi, distributor, valve covers too. You'll need to buy gaskets also. And be sure to scrape off any and all old gaskets.
When we did it on my 305 I just bought a Summit Double roller I believe it was , check www.summitracing.com .
You'll need new lifters with the cam and unless it's a roller cam will need to be broken in. Meaning you'll need oil/filter for 2 oil changes.
I'm sure i missed something, but I'm trying to give you the basics.
Oh, put a rag in the distributor hole and the holes on the intake ports.
Old Apr 14, 2002 | 12:06 AM
Car: 99 Formula
Axle/Gears: 342
Don't worry about a new water pump as long as yours is flowing fine, unless you want to save some weight and buy an aluminum one.
Also, you'll need to readjust the rocker arms once the cam is in, not exactly sure how to do it, I'll leave that for someone else. Also a trick is to put you lifters in some tranny fluid to help pump them up, just cut a milk jug in half and let them soak overnite, I think I remember Vader saying he put his in a pot and warmed the oil up some?
Old Apr 14, 2002 | 12:42 AM
mypontiac's Avatar
Car: 1991 Conv. TA
Thanks Mark.
Looks like I'd be getting myself in real deep here.
Might have to see how much my mechanic would charge to do this once I am ready to take the $$$$ plunge.
Guess I'll get the heads and cat back on first and worry about the cam later.
Thanks again to all!
Old Apr 14, 2002 | 12:41 PM
iroc22's Avatar
Are you talking about pre-loading the lifters?
If so you gotta keep tightening the rocker nut while you twist the pushrod with your fingers. Just at the point where it stops twisting, give the rocker nut a final 1/4 turn. But you pre-load the lifters when that valve is open.
Old Apr 14, 2002 | 01:31 PM
1986redbird's Avatar
if I recall, just soaking the lifters in a container of oil won't fill them, you have to pump the lifters with a rod while they are submerged in the oil so it will enter them.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
3rdgenparts
Aug 8, 2015 07:09 PM
