Cam Installation question
Old Apr 13, 2002 | 06:41 PM
ORAY777's Avatar
You don't have to drop the oil pan to get the timing cover off?
1991 Z28 1LE 5.7 auto.
Old Apr 13, 2002 | 06:57 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I don't think you HAVE to, but I took all the bolts loose on mine so I could pull it down 1/2". That little 1/2" gap buys you alot.
I know some have done it without dropping the pan at all but I didn't want to cut the inside lip off the timing cover.
When I put the cover back on I used a big glob of "The Right Stuff" rtv in the corners and it sealed up great. I also did a little around the studs at the corner too.
Old Apr 13, 2002 | 07:24 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
How well did your oil pan seal back up after you tightened the bolts?
Old Apr 13, 2002 | 07:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Didn't have to on my old 305, I believe my brother used some RTV around it as well.
Old Apr 13, 2002 | 08:37 PM
ORAY777's Avatar
Doesn't the bottom of the timing cover catch on to the oil pan or is there a trick way to pull the timing cover from the oil pan?
Old Apr 13, 2002 | 11:43 PM
ORAY777's Avatar
In response to my own question. I think it is easy pulling th timing cover off but not so easy putting back because when compressing the bottom rubber seal to the oil pan i have heard that it is difficult to do so. Anyone have any insight to this matter?
Old Apr 13, 2002 | 11:46 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, pulling it off was easy, putting it back on, my brother had a couple of choice words for this fu(cking piece of $hit 305. , but I guess he was happy he didn't have to pull the pan.
Old Apr 13, 2002 | 11:56 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
it was easy to pull the cover off but i had to loosen the oil pan to get it back on, used a 1/4" ratchet which fits in there pretty well with the engine in.
Old Apr 14, 2002 | 01:49 AM
ORAY777's Avatar
Hey Mark A Shields how did your brother Press that thing back in? I'd like to make my life a little easier ya know . I definetly do not want to pull down the pan cover because i really don't feel like having the headache of putting RTV sealant all around there especiall working from the bottom up. I'm really messy with that stuff.
Old Apr 14, 2002 | 02:11 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Mine sealed right up.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
