RAMAIR Question
Old Apr 13, 2002 | 11:48 PM
ORAY777's Avatar
RAMAIR Question
Is it possible to use metal hose ducting instead of the plastic ducting to use for ramair setup. At work i noticed air ducting from the ovens protruding into the ceiling. I think they were about5 inches in diameter. How large a diameter should you use? The metal ducting looks more sturdy also will it hold up to the ramair effect? I heard with the plastic ducting you have to stretch it or you will lose the ram air effect.
1991 Z28 1LE 5.7 Auto.
Old Apr 14, 2002 | 12:13 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I think you want something larger like the 5" you say, I don't see why you couldn't use metal tubing as long as you can route it easily and with it being that big of a diameter. Just make sure it doesn't come in contact with the battery terminals.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
