92 rs vs. 84 stang
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
92 rs vs. 84 stang
well, i finally got to get some good driving in on the camaro i just bought, and i had some kid in probably about an 84 stang gt try to get me to race. i wanted to, but i was heading a different direction. it sounded like it was a 5 speed, and it had an exhuast, and k&n stickers on the side, but it looks completely stock other than that, it looked like it had been beat on a little.
who would have won?
i just got a 92 camaro rs 305 5spd, with a 160 stat, and a k&n, other than that i think the car is pretty stock.
who would have won?
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
i was less than a mile from my house when i ran into him, so i'll probably let you know what happens.
also, a buddy in a 92 lx 5.0 vert aod wants to race, do i have a chance?
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
i meant to say that i'll probably see the kid again, and i'll post what happens.
zzzzzzzzzzzzzzzzzzzzzzz Senior Member
Engine: slowtacular L03 305
Transmission: slushem 700r4
The late model lx will whoop you the early 5.0 though may not be in the best of shape and as i remember they wern't the fastest of the fox body 5.0's so there may be a chance, but i am not a 5.0 guru so wait for someone like Nic to reply since he obviously has a bit more knowledge on the subject.
Car: 1993 Ford Mustang
Engine: 5.0L
Provided that it is an 84 and doesn't have significant mods, I think you'd come out on top. Same with the 'vert. My old 'vert ran high 15's bone stock and took what seemed like an eternity to get into the 14's.
My friend has an 84 GT. Hes got intake, headers and true duals, a bunch of msd ****, dual friction clutch, its dropped has big brakes etc. etc. Those cars with the 5 speeds have 3.08s stock and that kills them. I've driven his car several times and it runs really good but it just can't get up and go with the 3.08s. I say if he doesn't have gears then you will take him. The late model LX will kill you though.
Car: 99 Formula
Axle/Gears: 342
Originally posted by TPIterror
83-84 Mustang GT's(stick) have Holley 4 barrels and make like 175 hp. They're good for low 15's. It'll be a good race.
Car: Formula
Transmission: M5
Yeah...If I remember correctly, 15.3-15.6 range(I guess mid-low 15's). They're a lot lighter than the Camaro and put out a little more stock hp than the TBI.
I actually think those early carb gt's were a lot cooler than the later EFI ones.
Hopefully his carb will be out of tune!
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
i was figuring that it would be a close race with the old stang, hopefully i'll run into him the next time i drive the rs.
my friend w/ the 5.0 lx vert wants to race soon, im sure that i'll lose, but at least it will be a good race- his car might be out of tune, b/c i know it was acting up and losing vacuum.
btw, what did the lo3/t-5 rs run? i figured it would be right around 16 flat?
thanks for the help
thanks for the help
I'd say the 84Gt would be high 15's low 16's. I owned an 84GT briefly as a parts car. It ran and was the stock 4-barrel with a 5-spd and had an updated 8.8 rear with 3.55's and still was a total dog. The car would barely screech the tires. Maybe it was because it was worn down a bit.
When we picked it up i let a friend drive my LX and i drove the '84. We fooled around a bit and my friend in my LX made it look like i wasn't even flooring it in the 84GT
Car: Formula
Transmission: M5
Your 84 GT must have been out of tune. All times I've seen for those have them in the low-mid 15's. The 82 with 157 hp was a 16 flat car. The 85 was the fastest of the carb GT's with 210 hp. That ran high 14's.
If I seem to be rattling on about Mustangs, its because I owned two, a 79 pacecar and an 85 GT. Although, my interest in them ends there. I dont like the nose or the interior on the post 86 mustangs.
Engine: 5.0L
Maybe I overestimated the RS here. I think both races ought to be pretty close though. The '92 won't be as fast as everyone's expecting it to be I don't think.
Car: Formula
Transmission: M5
Actually(I know I'm **** about this stuff
83-84 5.0 HO 4bbl...176 hp(175 advertised)...247 lbs of torque
84 5.0 HO CFI..........165 hp.....245 lbs of torque
):83-84 5.0 HO 4bbl...176 hp(175 advertised)...247 lbs of torque
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
84' stang
They don't run in the 15's maybe 15.9 if they're lucky. I know that L69 thirdgens in 84 absoulutely blew those stangs out of the water, providing they were 5 speed w/3.73's. And you'd be lucky to get low-mid 15's out of those cars stock.
And Rs 5-speed suck, because of the gearing, and they sure as hell don't run 16 flat. Maybe Mario andretti can pull those #'s
Car: Formula
Transmission: M5
Dude..you're wrong..look at any old Motor Trend, Car& Driver, etc..
The times I quoted are correct. L69 5spds were also in the mid 15's. So neither car was "blowing eachother out of the water"
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
well, one of my first priorties, after i get the civic sold and the bodywork on the rs done, is to get gears and a posi rear end for it. i know the 3.08's aren't anything to brag about (better than the 2.73 auto like in my z, though) plus, i hate having a one-legged rear end- its cool to chirp 'em in third, but id rather have the extra traction.
so, if i had say a 3.73 posi rear, id have a better chance?
92camaroRSV6
Feb 11, 2001 08:53 PM
