ok guys....i really need to know if this guy can beat me
alright there is this guy who goes to my school and he just bought a 91 iroc daytona....he let me drive it today and it felt pretty damn quick! its got a turbo on it and i dont know what kind it is....but i need to find out cuz i was reading on fbody.com to c if he could beat me but apparently they put in two different kind of turbos on these cars and one model is suppose to be able to beat me....but one model i should take him easily!does anyone know of where i can find out this info or would anyone know this?i dont know what size engine he has either...please help he wants to race soon!
Just race him and find out, plus this needs to go on the street racing board. Moderator: can you move this?
He'll probably beat you if your car is stock, the dodge daytona IROCs had 224 hp and from the factory STOCK. They ran mid 14's. It's a TIII turbo 2.2L DOHC.
Race him, it should be close either way. Don't bet and don't worry.
The Daytona Iroc R/T is the one that made 224hp. Those are pretty rare though, I think they only made like 500. The normal Dayton Iroc made around 200hp still enough to beat some 305's.
Hawk92z-TDZ
close
- Join DateJan 2003
- LocationArthur, Ontario, Canada
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car92Z28, 99SS, 83Z28 & 86GTA
- Engine421, LS1, 327Turbo & 383
- TransmissionT-56, 4L60E, T5 & 4L60
- Axle/Gears4:10, 3:42, 2:73 & 3:27
- Liked:0 Times in 0 Posts
I beat an Iroc Daytona in my 88 IrocZ 305 TPI Auto. Totaly Wasted him. Mind u i bought that car with enuff mods that i was also taking out 350TPI cars.
It got stolen
I miss it.
It got stolen
I miss it.
Quote:
Originally posted by BORLAZ06
a iroc daytona
....if you have no mods then u are owned.
It's gonna take full exhaust (that includes headers), aftermarket intake manifold, better gears, and probably a better cam too. Run him from a stop if anything. And shut down early. DO NOT go from a roll. That's assuming you have a low output 150HP 305 (LG4).Originally posted by BORLAZ06
a iroc daytona
....if you have no mods then u are owned. PS - If you are going to ask who's quicker, you need to tell us a little more about your car. Auto, manual, regular low output 305, high output 305, any mods, get the idea?
If it is stock, then this will be a good race. He should be mid to high 15's easy stock. But if he has any mods, especially anything that has to do with the turbo, then you are gone. Definately race him anyway for fun and our own personal amusement though
You didn't mention his car having anything on it, so I would like to know who won. Also, those cars have a serious problem with head gaskets, so maybe while you are racing, he will blow it and then you will have no problem.
~Matt
You didn't mention his car having anything on it, so I would like to know who won. Also, those cars have a serious problem with head gaskets, so maybe while you are racing, he will blow it and then you will have no problem.~Matt
Quote:
Originally posted by Matt86t/a
If it is stock, then this will be a good race. He should be mid to high 15's easy stock. ~Matt
I guess you didn't read any of the above posts OR know anything about the 2.2 turbo Originally posted by Matt86t/a
It is capable of high 14s with an average driver, and should go through the traps around 92-94MPH. Certainly a lot more than a mildly modded LG4 to handle.Senior Member
Yea sorry Marc, I was thinking of my buddies n/a one. My other friend was going to buy one, but he never did. We did some research first, and it is a very fast car. The 4 cyl turbo kills the 6 cyl n/a by almost 2 secs in the 1/4mile. 84camaro, you could run with the 6 cyl, but not this one. Sorry about the wrong info before about the stock for stock thing. He has got you unless you do some serious work.
~Matt
~Matt
Rockin-Iroc
close
- Join DateJan 2002
- LocationMorrison, Colorado
- Car1986 IROC-Z
- Engine355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
- Transmission700R4, ratchetting shifter, 3.23 rear
Those were the best Daytonas Dodge put out. Unfortunately, they are rare and were soon replaced by the 3.0 liter V6 Mitsu engine. Then they were discontinued.
The engine is a 2.2 liter 4 cylinder. The block is standard Dodge Turbo II (because of the improved coolant passages and stiffer block), but the head is designed and built by Lotus of England. It's a 16 valve head with tuned port runners, just like half of an L98. The engine is fed by a Garrett T04 turbo with a 0.52 A/R ratio.
At a stock 11 psi (intercooled of course), he is making 224 hp. However, they are very easy to modify for higher boost, and can easily take it. Those engine rev to about 7 grand, and if modified to 15 psi (the highest you can go before hitting fuel shut off), he'll be making around 270 hp.
The IROC Daytona weighs approximately 2800 to 2900 pounds, so it's a few hundred pounds lighter than a 3rd gen Z28. So the power to weight ratio should be approximately the same.
What you can expect is a crisper launch while he battles turbo lag.
But that won't last long. His midrange will be about as strong as yours, and his top end will be more powerful. So you've got to try to shut him down on the launch and hope he doesn't catch up too quickly.
Do me a favor and ask him how much he'd sell that thing for.
Gawd I'd love to have one. I'm putting one of those Lotus motors into my Shelby Charger, which is only 2230 pounds. But it still won't be as beautiful as an IROC Daytona!
I've seen a few go for around $5500 and $5000.
You guys are blowing things out of proportion and scaring 84'Camaroboy.
The 224hp Iroc R/T, I repeat the IROC R/T didn't make production until '92 and are VERY RARE.
Here's the specs of the Daytonas through out the years.
http://www.allpar.com/model/daytona.html
I thought the 2.2 turbo started in 90 or 91. If it is indeed the 2.5 turbo, I think you would have a MUCH better chance. Again, run him from a stop, and try not to go much past 60.WOOOOOOOOO!
THANX FOR ALL THE TIPS GUYS...I BEAT HIM! took him right off the line pulled away from him pretty hard til third gear but he started to cacth up i beat him buy bout half a car from my rear bumper!
it was a sweet race....i might consider racing him again soon cuz he said he would think aboot i mean about a rematch! by the way my car was the L69 not the LG4.....its the HO 305 5spd with 3.73's at the rear.....plus im runnin hooker hedders with no cat(the bonus of living in canada!) flowmaster mufflers and a cam me and my dad threw in last fall....thanks guys ooh and if ya c one on the street give him a run...you'll be suprised how quick they really are...ahhh chevy!:hail:
Hawk92z-TDZ
close
- Join DateJan 2003
Nice kill.
Nice to see you won. Thanks for finally listing your car and mods
The L69 is quite a bit more car than the LG4, especially when modded. We wouldn't have had much of a discussion if you had done that earlier. I would have guessed you as the winner, even with the 2.2 turbo.
The L69 is quite a bit more car than the LG4, especially when modded. We wouldn't have had much of a discussion if you had done that earlier. I would have guessed you as the winner, even with the 2.2 turbo.Senior Member
Yea, where was all this info before? Nice kill man. Yea L69.
~Matt
~Matt
i tried to post it all be 4 but my comp was screwed and it never worked....anywyas im glad i beat him!....and we r still pretty good friends...and hell yes to the L69.....i raced a LG4 at the street races one night and smoked it .....i think he had exhaust too!
a iroc daytona
a iroc daytona
....if you have no mods then u are owned. lol good call N8
so whatever happen anyways? did u guys race?
YEA!! GO L69!!!
The L69 is the best 3rdGen motor in my opinion... and that proves why
Good kill
Good kill
Quote:
Originally posted by Air_Adam
YEA!! GO L69!!!
Good kill
YEA!! GO L69!!!
Good kill
imo
It's cool to see someone post results. Most posts usually leave you hanging.
