Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
1992 3.1L top speed?
Old Feb 28, 2003 | 01:39 AM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
i've got a stock 1992 3.1L, the speedo goes up to 120 and i've gotten it up to 115 with the needle still moving up, but the car was shakin pretty bad. guess my engine was starting to get pissed with me. any idea what the top speed on a stock '92 3.1L V-6 is? just curious....
Old Feb 28, 2003 | 10:45 AM
MdFormula350's Avatar
what rpm was it at? i would of guessed around 120 also.
Old Feb 28, 2003 | 11:45 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
i've had my 3.1 to almost 120(more like 115 or 116) once. But i had a perfect smooth ride. If your car is shaking, i would get the front end checked out. Don't want to fubar yourself.
Old Feb 28, 2003 | 12:31 PM
Car: 1987 Iroc-Z28
Transmission: auto
mdformula - not sure what the rpm's were at...back at home we have a 3.5 mile straightaway that has a divider on the left and guard rails on the right with no emergency lane, so no place for cops to sit, and i doubt one would be going fast enough over 115mph that'd they catch up enough to see me. (guess it'd kinda suck if your car broke down on that stretch of road...you'd be a sitting duck in the middle of the road ). i'm up at colege now though and the only straightaway is the highway but i'd be scared takin my car that fast on there..cops are way strict here. anyway, i don't remember what the rpm's were
9D1burd - yeah i might get the front end checked out. it felt like the engine was shaking and caused the whole front end to shake. everything drives excellent about my car except when i get up past 110mph...i guess with 117K miles, something had to not be perfect..
Old Feb 28, 2003 | 02:26 PM
Drakar's Avatar
Not sure but aren't V6's and the TBI V8's have a governor around 115MPH???
Im pretty sure the V8TBI's do but not so sure on the V6's??
You should check on that other wise top speed is 115mph!!
Old Feb 28, 2003 | 03:44 PM
89camaroRSV6's Avatar
if its totally stock ...should have a governer...
u need to change the chip to fix that...
most likely the VSS doesnt work good at that
speed.....the accuracy of the speedo's go bad
beyond a point.....
but ive had mine over 120...and mine doesnt
shake even a bit...in terms of the engine...but im
heavily modded..and an almost new tranny
though im wondering if u have an auto..and try
to floor it ...the car wouldnt shift to 4th ..there is a
stupid 4-3 downshift valve that wouldnt allow the
car to stay in 4th @ anything more than 3/4
throttle...(in other words full throttle upshift 3-4
is nearly impossible in non IROCS /GTA's or
unless u have a shift kit...with teh upshift sleeve)
so at almost redline in 3rd gear (drive) u should
be just over 100....if u have a 3.42 rear end...
Old Feb 28, 2003 | 04:27 PM
Drakar's Avatar
The 3-4 shift is a problem with ever 3rd gen 700R4 the only ones tat don't have it are the vettes, it is valve that you can change do a search the part is cheap to replace and it give you that 3-4shift in WOT.
Old Mar 4, 2003 | 07:13 PM
1QckSC's Avatar
It depends on a couple of things, auto or manual? Flat ground or downhill ? I've had mine over 120, I would guess around 130-135, but that is with a T-5 and a slight downhill grade. I'm not really sure in an auto on perfectly flat ground. I think the top speed is aerodynamically limited though, so it the cars drag would equal the power the engine is putting out.
Old Mar 4, 2003 | 07:43 PM
Car: 1987 Iroc-Z28
Transmission: auto
It's an automatic....and when I had it to top speed I had it floored, and I don't think it switched back to third gear. I think I would have noticed if it did, and everything seemed normal so I think it stayed in fourth. Oh, and it was on level road.
Old Mar 10, 2003 | 04:09 PM
Keoki_Firebird89's Avatar
back with my 2.8 and now with my 3.4 i broke my govenor... how i dun know...
but i've done 130 with both 6s
i know cuz of the prelude next to me... hehe...
i remember hearing it was 118 for the limitor to kick in...
i remember i got stuck there once before...
Old Mar 10, 2003 | 05:53 PM
Xceleratemaro's Avatar
i got mine up to 120 racing a mustang....he won
but my fuel pump was stright wired at the time so??? i dont know if that disabled the govenor if there is one
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
InfinityShade
Aug 22, 2015 08:00 PM
