85 LB9 vs 89 LB9
Car: 1970 Javelin SST
Engine: 360
Transmission: 727
85 LB9 vs 89 LB9
I drive a 305 1985 Pontiac Trans Am, and the potential racer drives a 305 1989 Pontiac Formula. I have 119500 miles, TPI, and a recent tune up, but mostly stock. The formula has almost 200000 miles, TPI, and is stock. Both are automatics. Who would win?
Engine: 360
Transmission: 727
Theres a small problem though. He does have a 305 in it, on his hood it says 5.0 TPI, but his friends say its a 4bbl. I havent got to look at it yet. Otherwise its a stock 305. He has all his trim in it.
I have taken out the ac, backseats, sparetire, and am running without a muffler for the time being.
Engine: 360
Transmission: 727
My car has t tops, and has the aboce items taken out. about 150 lbs or so.
the other car is a hard top, with full street trim from the factory.
I have no clue as to what gearing either has, but they both have the stock gears.
Car: 1994 Trans Am
I say 85. Much better cam. Less mileage, recent tune-up. 89 a4 has peanut cam any way you look at it, 200k miles. But race and find out anyway.
Car: 1989 RS Camaro
Well the tech specs say for 85 Trans Am with a LB9 and a 700R4 that you've got 215 hp and 275 foot lbs. of torque.
The Specs for a 89 Trans Am say that it has 195 hp and 295 foot lbs of torque.
You have a much better gear advantage with your 85 you've got 3.23 gears and he has 2.73. In 89 you had to specify G92 to get the better cam, which you have that gives you 215 hp. See but what you overpower him with in hp he makes up exactly in torque.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
WOW!!!!
This is almost identical to my friend jeff1367's car and mine!! He has a 85 TA t tops 305 tpi, mine is a 89 Camaro 305 tpi hardtop, both auto. He has 3.23 gears and I have 2.73 and he blew his engine at like 90,xxx miles and rebuilt it with a little better cam, after market heads, has dual cats, and free mods. His car has a little over 100,000 miles on it. Mine is bone stock with some free mods and has 150,000 miles and just the other day we were driving home and both hit it frim the line and it was dead even till the road curved. But we are racing officaly this week so I will fill you all in on the details after we race.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
the 85 will rev a klittle faster but the 89 will pull harder...its all on the driver...but me bein a bigger fan of torque ill go for the 89
nah dude the SD 305's were the quickest
85 was the year with the fastest of the 305's.
When you think about how the 305 was the only stick the fbods had to beat the mustangs with in the early years, well, I think it did well for what it was.
When I see that the stock '90-91 Mustang GT's make stock around 220hp and 290 torque, doesnt seem like it would be easy to build a 305 with better numbers. Again, ford is really impressive when you think about it.
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I've had 85, 86, and 87 305 TPI cars, all A4s, (85 and 86 both had 3.23s) and the peanut cammed cars do not hold a candle to the 85. I would give it the win by a good 2-3 car lengths assuming it's running right etc. The lower end torque is mostly wasted on the 89, both have enough torque down low and it will run out of the breath way earlier than the 85 thanks to the worthless peanut cam.
Then once you do the standard bolt ons the 85 will gain more as well, thanks to not being choked above all by the cam...
