I want to hear some iron duke kills
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Anyone have any stories of an iron duke beating a geo or something =D. Lets hear em' =D.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
id think it would lose agienst a 3cyl GEO with 3 fatpeople inside...
perhaps if you raced a moped on the top end from a roll.....?
Hahaha. Man, if I had a 4 banger camaro i'd be messing with everyone on my strip, i'd be hilarious racing grandma in her cavaliar and actually stay at my door.
Car: 2001 Firehawk - SLP Longtubes
My old 90 Grand Am had the Iron Duke and I could beat my girlfriend's Cavalier with it. this was back in 91, I can't remember what year the Cavalier was.
Car: 91 Camaro Vert
Car: 1999 Camaro Z28
I used to have a 90 buick skylark with the iron duke in it...mine was rated at 115hp and 135ft*lbs tq. it had a 3 speed auto and it took over 178,000 hard miles before she actually died...and the motor didn't let go until I blew up the TQ converter and tranny...once that happened it all let go.
I used to get out of the hole really good in that car...I could normally get accross the intersection quicker than anyone else...but depending on what type of car they had they would normally come back and kill me.
-Eric
-Eric
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
I was walking through the junkyard the other day, and I came across a firebird that had a few parts, and everything under the hood was intact. Looked a little closer, and it was an Iron Duke. Car was dead, but the windshield said the motor was good. Where there ever any mod parts for those things, and how easily would the 2.5 replace the 2.0 in a cavy?
There was one guy who built a iron duke because of a weight break he got in his class. I don't remember the times he was running, but it was quick. Try a google, he used to have a website a couple years ago.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I sure there had to be some iron duke camaro kills sometime. Maybe back a decade or so. It would be like a ***** getting a kill today, possible but very improbable.
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
Isn't is just a V8 cut in half long ways? Can't you put on stuff from a V8 just that you'd just use the one half.
Car: 91 Camaro Vert
LOL
that would work just as well as cutting the front off of all the V8 stuff to put on the 90* V6
Originally posted by 84 Challenge
Yes...it's basically 1/2 of a 301. You can use sbc parts (single head, header, etc) on it providing it's a super duty block. Which costs $2500 new.
Brandon
Brandon
, my 5 speed 4.10 geared S10 went 16.5@79 on the GTech... I think I might be able to beat the occassional K-Car
Originally posted by Marc 85Z28
You can use SBC rockers too. I've got em on my 88 S10. With a Pacesetter header, custom 2.25" exhaust, 1.6 rockers, and a chip
Brandon
Car: 91 Camaro Vert
I told you MrDude_1
I told you MrDude_1
and i told you too... and im sure theres also a couple bolts that work on both too....
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
I have never beat anyone with my Iron Duke Firebird!
Just because Ive got a decent looking firebird, a lot of people reved me at lights. I never even tried!
Its pretty sad when I do try.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
From what I understand, there is very little differences between the 2.5 in the S-10's and the fieros(mainly the block). If you have 1.6 rockers on, your robbing the motor of what power it has. A stock 2.5 in a fiero has 1.75 ratio rockers. You would also need to tap the head with studs to run them. Also, the heads should be different. But of course this is coming from the 2.5 in the fiero.
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
to reply to the one asking about changing the 2.0 out in the cavy for a f-bod iron duke, you cant do it. the f-bod iron duke is made for a RWD car, yours is a FWD. you can find one in a FWD car and it is a direct bolt-in...
Josh
Josh
Car: 1981 Oldsmobile Cutlass Supreme Brougham 2dr Coupe
Engine: 403 Olds v8, bored .030 over
Transmission: 350 T.H. 3A, shift kit
Keep an eye out for Automatic Celebrities with blown transmissions. There's your Duke.
sjorgens
Oct 1, 2015 07:54 PM
