Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Racing w/ 3.73's
Old Jul 17, 2003 | 11:26 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Racing w/ 3.73's
I was wondering how 3.73 gears do from a roll and when do they start to really leg behind in power. I know they do good from a stop but is that it? I have a 350 with a mild cam and stock 700R4 tranny. Any tips? Thanks.
Old Jul 18, 2003 | 12:06 AM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
My 3.73s pull all the way to 148mph. it depends on your motor. my mods are in sig. I think they are one of the best all around gear ratios out there.
Old Jul 18, 2003 | 11:53 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: Racing w/ 3.73's
Its when does your motor start lagging, its not the gears fault. My car pulls hard all the way to 110+ with 3.73's, I also dont run TPI.
Old Jul 18, 2003 | 01:33 PM
So these gears do good also from a roll?
Old Jul 18, 2003 | 02:02 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
i had 3.73s in my first fbody and they were great from a roll, it was a severe tire smoker!
Old Jul 18, 2003 | 02:47 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
about an hour ago i raced someone (first one ever really, that wasnt set up) and it pulled real hard to 120-125 when i shut down, i think it would pull hard to 140ish or better
Old Jul 18, 2003 | 04:03 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
If you have tip do not get 3.73s as it pulls you out of your powerband very quickly as tpi_roc might tell you. 3.73s are Great for a carbed car as it can breathe over 4500 rpms though. 3.42 is a better number for a tpi car, maybe even a bit lower, 3.23 or so...
This question might be better asked on the tpi board or possibly the drivetrain board, I'll leave it open for a bit but it's not really applicable to street racing.
Old Jul 18, 2003 | 04:08 PM
Ok sorry Inwo. Just wanted to know how these gears do from a roll. My car makes power above 4000RPMs it goes till about 4800. A lot of the races i get into are from a roll of about 35mph. The other races are usually from a stop or about 60mph. Its good to know i still have a lot of power with my new 3.73's even from a roll. My old 2.77's didn't do too bad but from a roll of 35 it didn't do too good but 60 holly crap! 60mph with my old gears is where the car would really come alive. Thanks for the reply's and if anyone else has a comment or advice let me know. Im hopefully going to pick up my car today!
Old Jul 18, 2003 | 04:15 PM
JesasaurusRex's Avatar
My 3.73s dont stop, love em to death, when my **** was tbi, it gave out in like 5th gear but an over drives and overdrive, now it still pulls through 5th like mad.
Old Jul 18, 2003 | 09:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The important thing is to have an engine that can rev high enough in the upper MPH's to keep you moving. 3.73's are great for Auto cars and t-56 cars. If you have a t-5 and have a near stock 305, which doesn't like RPM, you will suffer at higher speeds. A lot of LS1 guys run 4.10's but then again they can rev to 7k all day long.
Old Jul 19, 2003 | 11:22 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
They dont, like said it depends on your engine setup. I know mine have pulled hard to a calculated 137MPH (6200RPMs in 3rd gear).
Old Jul 19, 2003 | 01:52 PM
So a slightly modded 350TPI is still good with 3.73's? I still plan on doing a lot of modding but its going kinda slow not having a job. I just got the car back today and i do notice a big big difference but i cant really get on it because of a 500-1000 mile break-in period. And my speedo is way off. Doing 60mph it says im doing 80. Again, thanks for all the reply's.
Old Jul 19, 2003 | 08:52 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You will be fine with a slightly modded L98 and those gears will work great with the 700R4 and that motor. Go for it and you will be pleased.
JSDaddy189
Sep 26, 2015 03:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
82z
Aug 13, 2001 08:42 PM
The ODB
May 12, 2001 10:04 AM
StCr19
Jan 20, 2001 06:57 PM
