Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
3rd gen vs. 4th?
Old Feb 12, 2004 | 10:58 AM
84'Camaroboy's Avatar
Car: 84 Z28
Engine: 305 L69
Transmission: 5 spd
3rd gen vs. 4th?
hey guys....i got a quick question...this morning i traded in my 1996 Acura integra (winter car), and bought a 1998 trans am! i still have my sweet :hail: thirdgen. but i want to know which would win in a race. the t/a the ls1 6 spd. but is completely stock. my mods on my maro are in my sig. i was thinking that the trans am will take it but i havent driven the t/a all that much so im gonna get my good buddy who also owns a thirdgen to drive my maro(and yes he can drive) anyways about an hour out of town there is an abondoned air strip where we usually like to play around with our cars. if we run who will win?and by how much? thanks alot its much appreciated.
Old Feb 12, 2004 | 11:04 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
From what I seen, most stock Ls1's are around mid 13's. It will be close, but my moneys on the 3rd gen.
Old Feb 12, 2004 | 11:19 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
84' L69 HO
5 spd 3.73's
heddmen headers
3"exhaust "X" pipe
to flowmasters (no cat)
plugs and wires
k&n air filter
XE 256H cam
best time at track= 13.3@104.6
Huh? What else is done to your car thats got you running low 13's? By looking at your sig one would come to the conclusion that you have little more than a cam and headers in/on an otherwise stock 305 (No intake, heads, n2o, motor swap).
If your 1/4 time is real than I guess whoever's willing to push their car the hardest is going to win.
Old Feb 12, 2004 | 11:27 AM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
i dont see how you hit 13.3 on those mods...im barely there and i have considerably more mods. but i guess if you add in the factor that i cant drive, then i guess thats about right...
Old Feb 12, 2004 | 11:42 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Thats bs. 104 mph even spraying I would be skeptical.
Old Feb 12, 2004 | 12:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by SOLID LIFTER
84' L69 HO
5 spd 3.73's
heddmen headers
3"exhaust "X" pipe
plugs and wires
k&n air filter
XE 256H cam
I was thinking the same thing. Those mods don't seem to add up. If the 3rd gen is not putting 300 to the wheels then say goodnight, because the TA will own that 3rd gen bad. Even if your ET is a bit quicker that LS1 will run you down fast past 100mph.
Old Feb 12, 2004 | 03:23 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
that does sound pretty fishy.....a stock L69 runs 15's flat....but it seems you would have to have some pretty descent mods to dip down into the 13's...
Old Feb 12, 2004 | 03:38 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
13.3 @ 104 might beat the LS1 out of the hole, but the LS1 will start pulling hard once you get to the 2nd 1/8 mile. Should be a driver's race.
My 98 w/ nothing but an airlid and catback for "power" mods ran 13.5 @ 109 MPH. The 13.5 isn't that impressive, it was on stock RS-A tires and bad track prep (2.3-2.5 60's all day). But 109 MPH is enough for mid 12's w/ traction. Also, the 109 mph is w/ a 280 lbs driver and the spare and jack still in. You take the spare and jack out and have a 180 lbs driver instead of me, and it is around 110.5 mph. Not bad for 2 very simple mods.
Old Feb 12, 2004 | 04:19 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
if your LS1 doesn't hit low low 13s stock their is something wrong. i say if you run 13.3's in the 3rd gen, the 4th gen should take it, expesialy from a roll.
Old Feb 12, 2004 | 04:32 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
That is the best thing you could have done. I bet its big change going from that 4 banger to that T/A. I have always loved the 4th gen T/A. Good trade though.
Old Feb 12, 2004 | 09:12 PM
LS1Formula's Avatar
Car: 1989 Firebird
Engine: Toilet Bowl Injection 305
Transmission: Autotragic
You're either sandbagging with the mods or lying poorly. There's no way you're trapping 104mph on untouched 305 heads. Maybe 94mph, although I'm not sure that's attainable without spray. So with that in mind, a 6 speed LS1 car will absolutely destroy you.
Old Feb 12, 2004 | 09:28 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
Just going by what mods you have posted, that LS1 will tear you apart. And if we were to go by your 1/4 time, maybe you forgot a few mods to post, even then you might lose. Maybe up to 70 you would hang with your low 13sec timing, but after that the LS1 will slip away.
Its a loss either way, especially if those are the only mods you have.
Old Feb 12, 2004 | 11:26 PM
TexasLT1's Avatar
Car: '92 RS
I run 13.1's at 109 with the mods in my sig and I BARELY beat LS1's from a roll. From a stop, if I can get them out of the hole, its usually up to 2 lengths depending on the driver.
*Edit* Realized my sig doesnt have the mods anymore.
LT4 H/I/Hotcam
1.6 rockers
Heddman shorties
MSD ignition
3.42 gears
Old Feb 13, 2004 | 10:51 AM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
And all you'll need to do is an exhaust, lid, and some sticky tires...
I ran 13.0 @ 111 on a 2.1 60' with those mods. Once I actually heat up the drag radials, it'll be 12.70's or so
Old Feb 13, 2004 | 11:03 AM
Engine: 5.7
this is kind of off the topic but starting in 1990, the IROC's *then the Z28's from 91-92 with the 5.7 TPI's) came stock with 345 lbs of torque....and the stock 5.7 LS1's came stock with 340 lbs. Why is it that the TPI's have more torque? Just curious...hope it's not a dumb question....
91gta_tpi's Avatar
Car: 91 GTA
I love that you traded that ***** for a REAL car, good job!!! As far as the race goes, well let's see I think it would probably come down to who the better driver is/was!!!
Old Feb 13, 2004 | 01:14 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Well, to put that in perspective...
I dyno'd 329 ft/lbs at the wheels STOCK with 87K miles.
I'm not sure what a stock L98 is going to put down, but something tells me it's not going to hit almost 330 at the wheels.
Old Feb 13, 2004 | 03:15 PM
Engine: 5.7
then how come in the specs it says so? is it because it's not listed as on the rear wheels....?
Old Feb 13, 2004 | 04:34 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
No car has ever been rated at the rear wheels. The numbers you are looking at are at the flywheel.
You can compare numbers all you want, but a L98 against a LS1 isn't much of a match after the LS1 hooks up.
Old Feb 13, 2004 | 09:08 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
The L98 gets about 214HP/312TQ.
Old Feb 13, 2004 | 09:34 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Not bad at all.
One thing to consider...
Although the Z28 is rated at 310/340, we all know that's conservative. The vette is 350/375, so my dyno of 306/329 is right about where it should have been stock. +15% driveline loss is 352/378... I say that's pretty damn close
Old Feb 13, 2004 | 11:04 PM
Engine: 5.7
I realize that....
Old Feb 13, 2004 | 11:35 PM
Car: 84 Z28
Engine: 305 L69
Transmission: 5 spd
sorry about the confusion!
sorry about that guys i thought i had updated my sig. a long time ago.haha sorry. the other mods on the thirdgen are as follows:750 cfm,holley alum high rise dual plane intake, world products ported S/R torquer heads, manely valves,elgin valve springs,new badger pistons and rings,elgin lifters,push rods, and rockers my own version of "ram air", some nice sticky tires i lent, and a adjustable 100 shot of n2o.
and might i add damn!....having that 6spd in the t/a is sooo nice!
Old Feb 14, 2004 | 12:44 AM
Engine: 5.7
Re: sorry about the confusion!
I'd say that makes a difference....lol
Old Feb 14, 2004 | 09:22 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
I'd say it could go either way. If you're runnin 13.3's and the TA should run right there also.....it'll be a tossup.
Try running a couple times and it'll prolly go both ways.
Oh yeah, Way to go getting the TA
Old Feb 18, 2004 | 08:10 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
it will be a good race, untill you mod the :hail: LS1. i read over on the LS1 forums and i saw that... this guy had; a 6-speed 99 WS6 w/ cut-out, K&N, and a SLP lid. he whent, get this, on NITTOS 11.97 in the 1/4 mile.
i'm not saying the LS1s are better, but they have major potential. so good job geting a LS1.
Old Feb 19, 2004 | 06:59 AM
bigals87z28's Avatar
Car: Check The Sig
with thoes times, 100% dirvers race. Ive seen LS1's run the gambit from 12.7 to 14.5. Average will run low to mid 13's. Box stock 98 might run more twards the mid to high 13's. All depends on miles and so forth. Im gunna give the third gen the nod on the win, but it could go either way.
congrats on the buy too! How much was it? I know later 4th gens are becoming cheaper and cheaper. I wish it was the case for insurance rates.
Old Feb 19, 2004 | 03:23 PM
Marc 85Z28's Avatar
That is the biggest load of I've ever heard. Either he meant 12.97 or he has a cam/gears that he's not listing... They have potential, but not that much!
Old Feb 19, 2004 | 04:45 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
Ill end this right now...my dad has a 2001 T/A WS^ and he ran againsta an 89 Gta and sad to say, Gta at Dust...The 4th gen just blows past 100 w/o blinking..
Not related but for fun my dad raced my bro's 91 t-bird..it was a laughing matter...T/A hit 145 and T-Bird hit 115 on the highway..not real drag i guess..
-1-MEAN-T/A
Old Feb 19, 2004 | 05:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Maybe he just had a good run with perfect conditions. There are numerous guys running around 12.2 or less with similar mods. Most have headers though with the cut-out and all of them had drag radials.
Old Feb 19, 2004 | 07:01 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
belive what u what, but it happened, their are slips at the LS1 forums...
http://www.ls1.com/forums/index.html
go to:
LS1.com Forum > Performance/drag strip/AutoX > 1/4 & 1/8 Mile Times & Dyno Information > WOW! Car just keeps getting faster without any new mods.
(WOW! Car just keeps getting faster without any new mods.) should be near top of page 2 of the (1/4 & 1/8 Mile Times & Dyno Information) page................ THANK YOU.
Old Feb 19, 2004 | 07:07 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
well, back on topic, did the race go down???
Old Feb 20, 2004 | 12:05 PM
Marc 85Z28's Avatar
Here's a better LS1.com link, one I created just for you
The truth
Old Feb 20, 2004 | 01:20 PM
Dano 00TA's Avatar
Engine: LS1/L98
Yeah, as much as I love LS1's there aint no way they're gonna go 11's with the mods we're talking....unless alot of weight was stripped out of the car.
Old Feb 20, 2004 | 02:17 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
-1-MEAN-T/A
What do you expect? The GTA runs about 95mph and the TA 105mph or better...
Old Feb 21, 2004 | 02:23 PM
[superbird]
Guest
Posts: n/a
the last year of the lt1 was 97 so you have an ls1 but i would choose the camero
Old Feb 21, 2004 | 06:14 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I don't know if you mean engine mods only but a friend of mine that is a member of kyfbodies.org said there was a guy with a LS1 Camaro that had a throttle body, 4.11's, torque arm, relocated LCA's, slicks, and some other chassis mods go mid 11's. The engine was otherwise stock, but the chassis was highly modded. If the interior had been stripped he didn't mention it.
Old Feb 22, 2004 | 09:55 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
You know i go to the track and see them run and they just dont run as fast as they do on the internet....
Old Feb 22, 2004 | 12:41 PM
Car: 84 Z28
Engine: 305 L69
Transmission: 5 spd
THE RESULTS!!!
ok sorry it took so long to post the results....we ran twice last night out at the old air strip. once with the spray and once without. i was driving the t/a and my buddy the classic 3rd gen.
i had a friend start us off, right off the line the 3rd gen took me!he pulled about half a car length until i hit mid second gear, i started to pull on him and by the end of the race i beat him by just about 3 car lengths...that run was without the n2o. i was having troubles getting traction so the second race we went from like a walking pace roll, almost immediatley i pulled on him it wasnt until 3rd gear he pulled hard on me til the end...with the thirdgen spraying in the second race by the end, he beat me by 1/2 a car length.
it was 2 good races!.....either way im living the life i dreamed of. lol i cant wait to mod the ls1!but long live the :hail: thirdgen!
does anyone have advice on what to do next?!
thanks again.
Old Feb 22, 2004 | 12:48 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Next?
Lid, catback, subframes, and drag radials. That should keep you happy for a little.
Old Feb 22, 2004 | 03:31 PM
Dano 00TA's Avatar
Engine: LS1/L98
Re: THE RESULTS!!!
thanks again.
Sounds like some good races, as far as mods for the ls1 check my sig. They're keeping me happy.....for now at least
Old Feb 22, 2004 | 04:03 PM
  #42
BuckeyeROC's Avatar
Nice 84'Camaroboy.
As for LS1 mods, a lid and cutout and/or catback are a BARE MINIMUM for these cars. And I think a good shifter, such as Pro 5.0 or Ripper are a MUST for an M6 as well. Also recommend 4.10 gears w/ the M6 (probably my next mod). The 3.42's just don't seem like enough for the stock motor. Drag radials will help you get off the line. This should be plenty for 12's. After that, longtube headers. I think LS1's beg for cam swaps too, at least a 224/224 Should keep ya busy for awhile.
Old Feb 23, 2004 | 01:26 PM
  #43
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
[this is kind of off the topic but starting in 1990, the IROC's *then the Z28's from 91-92 with the 5.7 TPI's) came stock with 345 lbs of torque....and the stock 5.7 LS1's came stock with 340 lbs. Why is it that the TPI's have more torque? Just curious...hope it's not a dumb question....]
TPI motors create more torque due to the intake runner lengths. when mathced correctly with a cam, considerable amounts of torque can be achieved. the longer the intake runners the more torque is possible. thats if no other component in the motor hinders the torque. to get more in depth, the longer the runners, the faster the air will move through the curve. faster air, with correct timming and fuel mix will get lots of fun...
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
