Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Big Problem
Old Feb 21, 2004 | 10:24 AM
red85berlinetta's Avatar
Big Problem
alright guys heres the deal... i just raced a 1st gen neon with what he said had and intake header and muffler... i got a berlinetta with lg-4 that is rebuilt has a dynomax superturbo exhaust, edelbrok performer EPS intake, edelbrock performer carb, summit hei distributer, and a cam with 214/224 and .442/.465 lift cam. heres the deal ihave no tach cus my gauges are out but i was still shifting the car my self... i got it pretty high in the rev however this kid still pulled on me! i have a few questions... withthese mods whereshould my timingt be at? and with my auto should i shift myself or just put it in OD>? i have no idea how this kid beat me? however anytips or anyreasons for me not keeping up would be appreciated
Old Feb 21, 2004 | 12:04 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Well,I never race anything from a stop or roll while my car is in overdrive. You can put it in drive and just stomp on the gas or shift it yourself if you want afew more rpms, but at the top end you won't get anymore power for the few rpms you gain.
Laters,
Conrad
Old Feb 21, 2004 | 01:21 PM
yea but is there any reason for not doing it in OD? it seems like i get a little more power out of it cus it revs more... no idea. however is there anyreason for why this kid beat me with the mods i have?
Old Feb 21, 2004 | 04:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are way out of tune. My 4500lb vortec V6 truck would beat a first gen neon. You have major problems.
Old Feb 21, 2004 | 04:41 PM
well any idea on what might be wrong with the car? i mean i showed the parts i changed and whats on it now? id there any reason for this?
Old Feb 21, 2004 | 07:53 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
I had a first gen neon as a DD, and well, I have beat a vortec v6 in a silverado, no lie. I also had an auto.
My buddy has a nice little neon though, Itll give a 350 TPI a good run, NA. Its quick.
sorry to hear ya lost.
Old Feb 22, 2004 | 09:28 AM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Neon quick? Don't make me laugh! I used to beat lots of Neon with my 02 Cavalier Z22!!!
Old Feb 22, 2004 | 11:37 AM
sorry to hear i lost should not be a statement with the parts i have done... any reason why my xcar would be slow... i mean with the carb should i not slam the gas and instead slowly buil up
Old Feb 22, 2004 | 03:18 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No you need to mash your gas. You are extremely out of tune. Either your carb is out of tune, you have your timing wrong, or you have a bad AF ratio going. I do not know much about dialing in LG4 cars so I can't offer much more. But a full exhaust and cammed LG4 should make way over 200hp and 300 lb ft. There could be a lot of things wrong with your set-up.. A bolt on first gen neon is no match for a 350 TPI by the way. Not even in the same league.
Old Feb 23, 2004 | 08:17 PM
well the timing is at 10 degrees advance with the cam cus its 214/224 .442/.465 and with the carb i think i need to adjust the WOT metering?
Old Feb 23, 2004 | 08:45 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
I used to have an Lg4, and boy, I would be very suprised if that thing would beat a Neon on on 3 cylinders. I have a friend with a pretty quick 1st gen Neon, single cam too. He's only got bolt ons and he has taken out TPI 305s without a problem, he can easily run with my buddies 89 GTA L98. Its close, but I wouldn't say that a Neon can't be in the same class. Oh yeah, its a Cavalier Z24 by the way I have a 98 for my winter beater, very very slow
Old Feb 23, 2004 | 09:03 PM
yea but with the carb, EPS intake, that cam, and the exhuast i ought to be pushing at least 220 hp? i have to have some tuning issues or something? does 10 degrees advance sounds right for the setup i have?
Old Feb 23, 2004 | 09:59 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
10 may be a bit high. I would start at 4 and work my way up. Most cammed 305's like between 6 and 10. There are lots of varying factors but it is a starting point. Someone who knows how to dial in a LG4 is gonna have to chime in. If was an LO3 I would be all over it. I don't understand the computer controlled carbs at all.
Old Feb 24, 2004 | 09:21 AM
well can someone good with lg4's please chime in? o yea and by the way the carb on my car is not computer controlled... it is and edelbrock performer 600 with performer eps intake the cam i sepcified and a dynomax 2.5 cat back.... any info on timing and carb setup would be apprectiated
also i have a summit HEI 50,000 volt distributer
Old Feb 24, 2004 | 11:19 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Do you have any track times? With your mods you should be at mid to high 14's all day long. No way is a bolt on neon even going to be close to that. The SRT4's are a different story. But your average run of the mill neon will run 16's.
Old Feb 24, 2004 | 03:59 PM
that why i know there is somehting wrong.. can anybody chime in on what the timing should be on my car if its an lg4 with the parts listed above? right now im at 10 degrees advance... might be to far
Old Feb 24, 2004 | 10:37 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
you guys dont think the neon i talk of is legit? This fri or sat he is racing a minor bolt on lt1, maybe on video, but we know the thread will be closed if i show it.
This neon is legit, i have ridden in it. I will let you know the results soon.
Old Feb 24, 2004 | 10:49 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
What does this neon have. It would have to have serious mods to even hang with a cammed 305. You do realize that a stock LT1 can still beat a stock SRT4 neon. Sure it is close but that is a turbo car that puts 220 to the wheels. A first gen neon with bolts ons is no where even near the numbers of the new SRT. My buddy drives one and so does my cousin. Both are mid 90 cars or so or whenever they first came out. They have like 100 hp and are horrendously slow. A cat back and cold air kit will only make them super slow instead of my previous rating. THere is somthing wrong with his car and he needs some LG4 experts to help him dial it in.
Old Feb 24, 2004 | 11:23 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Your convertor is not locking up do to the fact that you put on a after market carb that may hurt you a little.
I would say take it to a local shop and have them tune up your car and replace plug and wires.
Get your gauges fixed and and shift it around 4200-4500 RPMs you can feel when its stop going through the peak.
Old Feb 25, 2004 | 06:42 PM
it has new plugs and suff.. the engine was just rebuilt... im starting to think that it is the carberater, i think its going to rich on the WOT
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
