Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
wonderin if i could win
Old Mar 7, 2005 | 01:14 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
my friend has a 88 stang lx 5 speed all stock but i think he said somthing bout hes got a cobra clutch or something other than that his car is all stock my mods are 2.5 flowmaster exhaust high flow cat and an open element nothing big ... is he a threat? and if i loose would this trans-go street/ strip with the corvette servo shift kit help out alot?
Old Mar 7, 2005 | 01:16 PM
MoroteZ28's Avatar
forgot to add his stang is a 88 5.0 5 speed
Old Mar 7, 2005 | 01:40 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
I think you can get him.
Old Mar 7, 2005 | 02:07 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Hmmmm....this question sounds very similiar to another we had just recently.
Anyways, I'd say your toast!
Old Mar 7, 2005 | 02:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is impossible to tell without knowing anything about your motor.
Old Mar 7, 2005 | 02:46 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
If hes stock, it would be close, but you should take him. It will depend on the driving, state of tune and tons of other stuff. If he has gears or anything of the sorts, Id lean towards his car!
I say go race and find out!
Old Mar 7, 2005 | 03:40 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
your trans comes with a vette servo stock. dont buy one, you already have one.
Old Mar 8, 2005 | 05:41 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
why would you assume his car has avette servo? its a motor swap and probably has the 82-86 700r4.
Old Mar 8, 2005 | 08:10 PM
MoroteZ28's Avatar
i got a 700r4 i thought they had the billit servos???
Old Mar 8, 2005 | 08:13 PM
MoroteZ28's Avatar
i got a gm goodwrench 350 with the 2.5 flowmaster exhaust with a high flow cat and a open air element wit a 3 inch cowl if that helps
Old Mar 12, 2005 | 05:53 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
What kind of intake and carb do you have? Its still hard to tell if you will present a challenge! If your 700R4 was mounted to a 305 you need that servo installed its easy to install anyway so put it on. Definitely install the shift kit thats a must. Also get yourself some cheapoo 1.6 stamped rockers because not all stock rockers are 1.5 some have been proven to be smaller like 1.47 which is robbing you some lifted on that already small cam of yours. An in just about every magazine has proven that adding 1.6 rockers will give you 10-15 more hp.
Old Mar 13, 2005 | 09:47 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Stock? No it doesn't.
Old Mar 14, 2005 | 10:34 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
it can all come down to who is a better driver and who doesn't stay in bewteen gears longer.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
Angie Coots
Sep 23, 2015 07:42 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
