is this a good zero to 60 time?
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
this a good zero to 60?
i was playin around with my new gtech lastnight. my best 0 to 60 time was about 8.2 seconds in my lo3 ws6 formula i didint think that was a very bad time condsidering there was a 200 pound pasenger and had 3/4 tank of gas. just wondering what you guys thought oh and my car is stock besides a 14x3 open air and ultimate tbi mods.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
That sounds about right, maybe a little too fast. G-Tech's aren't known for their accuracy.
Car: '92 Z03
Engine: LSX
Transmission: M12
Might give you a rough idea / be close, but if you want real times, take it to the track.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That sounds about right givien the conditions but that number can be greatly reduced the nest time you run. G-techs are pretty acurate when it comes to timing but are usually a bit fast when calculating MPH.
Car: 1988 formula
what do you think my time would be with just me in the car and about 1/4 tank of gas? i cant realy see what my time is without my dad in the car cause i only have my permit
so itle be a little over a year befor i can see what my car realy has in it. and acording to gtech it can give or take about .2 seconds
so itle be a little over a year befor i can see what my car realy has in it. and acording to gtech it can give or take about .2 seconds Last edited by f_body_4_life; May 22, 2005 at 06:22 PM.
Car: '90 RS
Engine: 377 LSX
so itle be a little over a year befor i can see what my car realy has in it. and acording to gtech it can give or take about .2 seconds Originally posted by ShiftyCapone
You should be able to get that time down to the mid 7's. Cooler weather is a TBI car's best friend.
Keep the gas in the tank, it will aid with traction, which greatly affects 0-60 times.
If you had a manual with 3.23s or better with some other minor bolt-ons OR add headers and full exhaust with a posi unit to your current combo mid 7s is reasonable. Remember, a mid 7 second 0-60 roughly translates into a mid 15 second quarter. And you're not there, yet
ShiftyCapone may know more than I about the TBI cars, but his L03 performance claims are usually a little far fetched.
Car: '90 RS
Engine: 377 LSX
When I had my car, I put some washers underneath the brackets that held the hood on in the rear so it was lifted up about half an inch (side closest to the windshield). Isn't that a pretty common thing for hot rodders to do? Just for the record, I never noticed a difference.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I took the sound deadening material and weatherstripping off the rear of my hood to get more airflow through it. However, I have a TPI and a CAI down right below where the charcoal canister was before I relocated it a little bit. I did this at the same time I added my SLP 1 3/4" headers because I know how much warmer headers can make the engine bay. Don't know if it needed to be done, but I figured why not.
May help on a car with an open element. Sure couldn't hurt anything I wouldn't think.
Car: 1988 formula
well I have the stock cowl hood that came with my formula and I took out the peace of metal a replaced it with a mesh screen so I could get some cold air under the hood I think cooler weather might do something because it was a very humid 85* when I ran that and my engine temp was 220* so maybe if I put in a cooler thermostat and wait for a cooler day I might make some better times
but we will just see how much of a difference that really makes its supposed to be in the 50's tonight im going to try and go out and make another run just to see how much of a difference that really makes
Ghettobird52
Jul 5, 2024 11:18 PM
Linson
Aug 21, 2015 02:12 PM
