cam'd LT1 times?
Car: 91 Z28
Transmission: 4l60e
cam'd LT1 times?
k guys going 2 be installing a lt1 in the spring and was wondering what i could expect at the track here is the build
LT1/4L60E
Transgo shift kit
2500-3000 stall converter
4.10 gears
230/236 @.050 544/555 with 1.6 rockers
Full exhaust
Subfram connectors
and maybe a 100 shot of nitrous but not sure...
LT1/4L60E
Transgo shift kit
4.10 gears
Full exhaust
Subfram connectors
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
I had an LT1 with simliar cam, 3.23's, no nitrous. Went 13.6 on a hot humid day spinning clear to the 60ft. Definetly could have gotten high 12's on a good day with traction.
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
You guys are kidding right? With those mods, should be very low 12's with decent traction. With some nitrous, easy mid 11's.
I went 12.4 with a HOT cam and full emissions still on it in my 96 WS6. And the HOT cam is no where near as big as that cam.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
wow thats pretty impressive for a hot cam. i guess thats about 400hp on crank which should be mid 12's or so
i know its definately gonna be a 12 second car... basically thats a miniram L98 with a big cam and slightly better heads. those combos are easy 12's lol
Car: 91 Z28
Transmission: 4l60e
sweet i think with the 100 shot i would dip into the 11's then with a 383 kit that fall with a bigger cam and heads reported im assuming it would be close to bottom 11's high tens and maybe up the nitrous but i dunno im kinda iffy on upping the nitrous all in all its gonna be alot more fun 2 srive then my ****ty 305 tpi that only went 14.86 @ 97 mph
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
If i keep the car in the spring, its getting that 3200 stall with either 700r4/3.73s or T-56/4.10s. I'm looking for high 11s on motor and 10s if I spray. My car is quite a bit lighter than stock though.
Car: 91 Z28
Transmission: 4l60e
so what all would be needed for suspension and chassis so i dont twist my car and so it hooks off the line i know i deff need SFC's but i don know a whole lot about suspension/chassis and need some advice
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
LCA's
LCA relocation brackets
Different springs (depends if you want track or street)
Shocks (application varies on use of car.....see above)
Good tires
Car: White KSwisses
Engine: 5.3L Gen III
With those 3 mods on the WS6, I could cut 1.7x times on Nittos.
Some go to a torque arm and relocation brackets but I didn't. Well I did have an LG Motorsports TA but it didn't do anything in drag racing. Great for brake dive and axle hop on corners though.
