Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
What do you think?
Old Feb 10, 2006 | 11:05 PM
icebird_1981's Avatar
What do you think?
What do you think this will run in 1/4 Mile? Its a 1983 z28 pushing 350hp at the rear wheels and almost 500ft-lbs of torque at the rear wheels? its got 3.42gears and a th350 tranny(just rebuilt) with shift kit.
Also how would it stand up to a civic hatch with a prelude engine and lite mods? Dont know what engine is, all i know is it came out of a prelude and suppost to be fast.
Old Feb 10, 2006 | 11:21 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
You should trap ~110.
if you're putting down 350 rwhp you have nothing to fear from any N/A honda engine.
Old Feb 10, 2006 | 11:36 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Do to the fact that you are guestimating your power output and don't give enough info to base your guestimation off of. I will guess that you have a mid 13 second ride.I would say that if the Civic is an N/A car then you would probably win.If it has a power adder it might get you.
Old Feb 11, 2006 | 12:09 AM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
It only takes 330hp rwhp to run low 12s in a fbody but thats if you have that much. What heads are you running and cam profile? Also if the civic doesn't have a turbo why even bother ask? Does it have a 250 shot or something?
Old Feb 11, 2006 | 12:28 AM
stu's Avatar
stu
The Civic will be no problem for you. It's got an H22 or H23.
Old Feb 11, 2006 | 10:49 AM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
You are right about what could be done with 330 rwhp in an optimized set up.Usually when people don't really know what they have they end up dissapointed when they finally get it to the track.A full weight street camaro with the average hotrodded 350 3.42 gears and a th350 would most likely run somewhere in the 13's.
Old Feb 11, 2006 | 11:01 AM
comp's Avatar
Old Feb 11, 2006 | 12:14 PM
those are the numbers from the dyno session, so yes there right. its a modded 355 sbc with a martin turbo system, engine is balanced and blueprinted.
Old Feb 11, 2006 | 05:32 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Then you should be easy 12's with nothing to worry about
Old Feb 11, 2006 | 05:37 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
You should be in the 12's. As far as the honda goes
Old Feb 13, 2006 | 09:30 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Your toast dude.
Old Feb 13, 2006 | 07:46 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
A turboed 355 is only making 350 rwhp? My friends stock bottem end, stock cam, stock heads (milled, bigger valves, and a great valve job), Explorer intake and bolt on 5.0 made 310 rwhp...
Id find the missing power in the car, and then go out there and not have to worry about many cars!
Old Feb 14, 2006 | 03:54 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
yeah a turbo'd 355 only making 350 RWHP??? My buddies 5.0 Fox with full bolt ons STOCK heads and a HPS (hellion Power Systems) turbo setup on a VERY streetable and mild tune (6-7psi) put down 452RWHP.......so somethings missing in your combo man?
Old Feb 17, 2006 | 07:07 AM
wheelstandin87's Avatar
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
Easy Race if you have what you say you have!
Old Feb 17, 2006 | 12:31 PM
its not done yet, still needs some stuff along with tuneing to get it running right. When it done it should be around 500HP, i was just wondering how i would do now/as is.
Old Feb 19, 2006 | 04:02 AM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
with 500 lb'ft of torque, I would think that its in a low rpm, so he is gonna spin a lot. I guess low low 14's or mid to high 13's.
Old Feb 19, 2006 | 04:27 PM
Car: ws6
Engine: ls1
Transmission: m6
All he needs is some traction.
