Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
85 Z-28 Vs 350 zx & RSX
Old Apr 11, 2006 | 11:07 AM
19kilo's Avatar
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
Two guy's at work want to race me a 2006 350 zx (STOCK) the guy said it is the track model whatever that means another guy has a 2004 Rsx type S with just a intake and exhaust I have a 1985 Z-28 with stock 3.08 gears how would i do?
MOD’s
1985 Camaro Z-28
350 bored .030 over (355)
Balanced
HEI distributor
Edelbrock RPM
Comp cam Lift .447/.447 Duration 290/290 Duration is .050
Pacesetter shorttie headers from jet hot / y-pip coated
High flow Magna flow cat
3 inch piping flow master 80 series muffler
K @ N Xstream air cleaner
Ac Delco plugs Megafire wires
Air inductions hood
180 thermostat
Old Apr 11, 2006 | 12:12 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I don't think your cam is a 290/290 at .50 with a .447 lift. That sounds like a stock eliminator cam LOL it's probably a 290 advertised, which is still a healthy cam.
What heads are you running?
Old Apr 11, 2006 | 12:48 PM
stu's Avatar
stu
It's a 350Z, not ZX. I think you'll beat both of them. RSX's can be quick N/A with an ECU reflash and cams and stuff, but this one is nothing special.
Old Apr 11, 2006 | 12:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You should beat the RSX but the 350Z will likely hang if not beat you.
Old Apr 11, 2006 | 02:40 PM
stu's Avatar
stu
350Z's can be pretty quick with N/A mods like cams, intake, and exhaust and stuff also.
Old Apr 11, 2006 | 02:52 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Ive personally raced a 350z or two in my 89 L98. i would pull hard on him thru first and then they would get within a fendor or so and pretty much stay there before i shut down. (50-60) Light to light i would beat em, and on the freeway im sure they would walk me.
You arent running the LTR setup (and my car was pretty stock excluding free mods and full exhaust) so i would say you wont have much of a problem with these cars.
Old Apr 11, 2006 | 04:16 PM
stu's Avatar
stu
I think as long as you can consistently run in the 13's on the street with little driver error you should have the 350Z.
Old Apr 11, 2006 | 06:06 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Old Apr 11, 2006 | 07:43 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Even if that duration is advertised it still seems high for that lift.
Old Apr 11, 2006 | 09:01 PM
Car: '72 Chevy Nova
Transmission: TH350
Yeah it does, like it said, looks like a stock eliminator cam
Old Apr 11, 2006 | 09:44 PM
19kilo's Avatar
This is my cam specs right off the box's
Valve Lift .447/.447
Cam Lift .298/.298
Duration (SAE) 290/290
Valve lash HYD/HYD
Centerline 110/118
Spread 114
Timing Events .050 cam lift
I dont understand what you guy's are saying about the cam???
Stock heads right now they where totaly redone i put new lifters on them
Old Apr 11, 2006 | 09:48 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Cam Lift .298/.298
Valve lash HYD/HYD
Centerline 110/118
Spread 114
I don't think the duration numbers you are giving are at .050 lift. I think it is total duration. 290 duration at .050 (what is typically advertised) would be top fuel style. What heads are these "stockers". Do you have casting numbers?
Normally a cam with .447 (assuming 1.5 RR's) and a 114LSA will have around 215 or 200 duration at .050.
Old Apr 11, 2006 | 11:12 PM
19kilo's Avatar
I have no idea what the casting numbers are the block came out of a 1974 Camaro 2 bolt main. That Cam is it good or bad what are you saying about it not trying to be rude i dont understand?
Old Apr 12, 2006 | 01:23 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Is that a Crane "Blueprint" cam? If so it has 222/222 dur @.050 w/ .447/.447, it's an old *** design from a factory hi-po 327ci engine.
I don't know how well that will run in some smogger motor w/ low compression and crap heads, it's kinda an outdated cam. You're probably only pushing around 300hp max, safer bet might be 275.... Should be a close run w/ the 350z, I think the track model has 300hp as well, over the 287hp in the standard models or whatever... {Edit - 2006 models all have 300hp if they're a manual, 287hp for autos according to a page from a quick google search}
Practice your launches and make sure you don't spin too badly out of the hole and maybe you can take him. Hard to say how well yours will run.
Old Apr 12, 2006 | 10:06 AM
stu's Avatar
stu
Track models are lighter with different wheels, not any more horsepower.
Old Apr 12, 2006 | 06:13 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
19Kilo, I forecast that the 350Z will completely waste you. You have junk heads and no compression, you are lookin at about 260hp. My guess is your car runs 14.50s at best. Prepare to be handled.
Old Apr 12, 2006 | 10:03 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Originally that's all it was, they had the extra HP over the standard models in 2005 only apparently from some reading (along w/ the 35th anniversary edition). The base and touring models or something still got the 287hp setup in 2005. 2006 now they all get the 300hp engine if equiped w/ a 6spd manual, back to 287 w/ the autos...
Old Apr 12, 2006 | 10:28 PM
19kilo's Avatar
Well how do i up the compersion?
Old Apr 13, 2006 | 11:11 AM
1989iroczaz's Avatar
Car: 1989 camaro iroc-z
change the pistons or change the heads
Old Apr 13, 2006 | 12:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
What heads are you running. Which "stock" heads do you have. GM produced hundreds of "stock" heads over the years. MorTec, Inc. Home Page
Old Apr 13, 2006 | 03:29 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Take off your drivers side valvecover and look at the casting #s and look them up.
Old May 6, 2006 | 01:32 AM
michal_larson's Avatar
im running a duntov 30/30 wich is 254/254 @ .050 and .455/.455 lift @ 114 lobe sep. its 360 degrees advertized
Old May 7, 2006 | 11:04 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
That dosent sound right. Maby 254/254 avertised duration. My cam is 224/230 @ .050 with .477/.480 lift. For a cam with 254 duration @ .050 they usuraly have around .555 to .6 lift.
89fast5oh
Sep 8, 2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
