Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
383 vs 1.6 SOHC VTEC TURBO
Old Jun 27, 2006 | 03:27 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
What do you guys think
1995 Honda Civic SOHC VTEC with TURBO, Intake and 3 in Exhaust - This is not a ***** CAR
not sure on Hp
vs
1987 Pontiac Trans AM - 383 Stroker, With Hot Cam and 1.6 Rockers
Chambered Exhaust, Headman Headers, T-5 weak tranny.... Orginal 10 bolt in back with 373 gears
425 Hp
416 Tq
Who would win
I guess i cant write R_I_C_E_R
Old Jun 27, 2006 | 03:46 PM
stu's Avatar
stu
You gave ZERO info about either car. How can you expect to know how fast a car is without knowing the weight or power?
Although you did mention that he's running a d-series motor so I'd say that you are probably safe on this one. He could be running a lot of boost on a large turbo with nitrous and have a lot of weight savings done, but I doubt it. The fastest I'd worry about that car going is mid 12's.
Old Jun 27, 2006 | 06:52 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
From a roll it should be a good race. From a dig you should take him assuming you can launch.
Old Jun 27, 2006 | 11:28 PM
stu's Avatar
stu
I doubt it will be a good race at all. Making a d-series motor fast with a turbo is one step above going N/A. It can be done, but it's not really worth the money/effort. Plus you really can't go all that fast without having a full race car. Remember how I said that the k-series is the LS7 of Honda motors? Well the d-series is the 305.
Old Jun 28, 2006 | 07:39 AM
kelham's Avatar
which ones the k series in the hondas... im not to familiar with imports
Oh the civic is pretty much stock weight
the TA is 2895lbs
Old Jun 28, 2006 | 09:32 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yep stu is right... turbo sohc cars can be somewhat quick but not reallly fast. your 383 sounds very stout and should be fairly deep in the 12's. i think you have this one. as long as that 10bolt and T5 hold up
Old Jun 28, 2006 | 09:57 AM
stu's Avatar
stu
The 6th and 7th generation Civics. All the RSX's. I think they started putting them in cars in 2002.
If the Camaro only weighs 2,800 lbs, there won't be a problem.
Is this thread a joke? Seriously.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
JSDaddy189
Sep 26, 2015 03:50 PM
