How fast is a stock 89 TTA (really)???
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
My supervisers son is interested in buying a 03-04 cobra... He wants to be able to smoke his dad (87 Buick GN). Im trying to talk him into buying an 89TTA instead. Ive been doing some research on them, and i am starting to lust for one myself.
Honestly, how fast are these things bone stock??? Why is it so much faster than a bone stock GN with the same motor?
I already have a rivalry with his dad. We have identical ET's. I hope im not gonna get smoked by his kid!
Heres some vids i dug up on some TTA's
Enjoy
listen to the turbo whistle before the launch.
StreetFire - 89 TTA vs LT1 Formula (Video)
this looks like an LT1 Trans Am getting smoked again.
Video - 1989 20th Anniversary TTA vs LS1 Trans Am
just watch the launch on the stock wheels.
Video - TTA vs TTA at BMP track rental
The potential of the stock longblock
Video - My 89 TTA on the dyno, 100% stock long block.
Enjoy
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Anywhere from 12.9 to the 14's. If you know how to drive them, easy low 13's. If you got a real good one and know how to drive them, you can dip into the 12's as a couple have been there bone stock. But that was back in 89 and 90 when they were new.
State of tune now would depend on how it ran. Have to remember they are 17 years old now. At the very least, new plugs, filters, and valve springs would need to be replaced.
Car: 1991 Camaro
Justin
Car: 1991 Z28
Engine: 5.7 TPI L98
I know they are rated at 250HP, but i bet its closer to the 300 range.. I want one real bad now. I don't really care for the GTA dash much. I like the look of my Z28's better.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The 1989 TTA's I have seen ran high 13's stock. Now with some modifications they are real screamers. One locally is running in the 11.70's.
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
I think you guys are waaaaaaaaaaaaaaaaay overating the TTA's.
The ones I ever see (remember he said the stock ones) are running high 13's low 14's.
With decent drivers.
Let's not get carried away with the 'low 12's' stuff. C'mon.
Maybe on slicks, with the interior gutted, with a rolling start, down a dragstrip built on an incline..........................you know what I'm getting at.
Its incredibly easy to make them run low 12's but nobody ever said low 12's bone stock. Mine ran 12.1@111 with about $500 and that included Nittos. And still on pump gas!
There really aren't that many stock TTA's around. Most have at least a chip because the stock chip is way too aggressive for today's gas. I couldn't even run the stock boost in mine with the crap gas of today.
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
yeah, they run low 13's and really make 301 hp stock. They low balled the hp at 250 for warranty issues. The TTA makes more HP then the GN for afew reasons but it had better heads. The buick heads wouldn't clear the strut towers but Pontiac used there own heads with made more power and cleared the towers.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
I can go call up a friend of mine and he can run all 3 of his and they'll all run similar times(mid-low 13's), hell even the one with 2.77 gears(was in the Silver State races, hence the 2.77's) ran 13.5's with **** gears.You also have to take into account your altitude...where are you? The tracks near me and Rob are at sea level.
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Car: 2018 Camaro SS
Originally Posted by stu
The difference between sea level and a mile above sea level can be less than half a second with a turbo car. And that's a whole mile. Anything else and you guys are over exaggerating results.
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
[QUOTE=Manic Z]I think you guys are waaaaaaaaaaaaaaaaay overating the TTA's.
QUOTE]
Ditto.
QUOTE]
Ditto.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i have heard mid 13's and thats bout it.
i think they are gettin overated as well..but still very quick cars
Car: 89 Formula 350
here's a good link
1989 Turbo Trans Am Feature
I don't think the TTA is over rated. I had to do all the mod in my sig to my L98 to run low 13's like a stock TTA
Very easy to screw up how the TTA runs. Say you have a run with a 2.0 short time and 1.88 short time. Both easily achieveable in a TTA with stock tires. Only problem is, the 2.0 short time came from a at idle launch. The 1.88 short time came building boost on the line. I can tell you by the 1/8 mile, the 1.88 launch will be .5 second ahead of the 2.0 launch.
There is a big difference in ET when you can hook/launch under boost. I used to play with mine in all kinds of launches and know the results.
Just some FYI
Just some FYI
Car: 2018 Camaro SS
Just some FYI
Just some FYI
But Rob all these guys have so much experience with these cars, surely they knew that.
I know what they run stock and slightly modified. To me, it was easy driving mine. Maybe it was from having a GN or a 84 Z28 and 96 WS6. The TTA was the easiest of any car to launch that I've ever owned. I have yet to get anywhere near the 1.61 short time with just drag radials and stock suspension that the TTA would do.
Car: 89 Formula 350
Originally Posted by Sidewayz28
haha yeahh... uhhh 03/04 cobra > TTA
any day...
any day...
any day...
any day...
But it should with 100HP more
But once you start modding, I'd take the TTA. The glass jaw rear in the Cobra can't take the strip too well. It would be interesting to see a mod for mod/dollar for dollar comparison though. That would be a good race!
Terminator mustangs are insane, they finally got the cobras right with those, TTAs were the equivilant in their day, but a good driver in one of those cobras will smoke alot of what is out there even now in bone stock condition. A modded TTA could probobly give it a run for its money however.
Car: 1991 Camaro
got a buddy with just exhuast, pully, and a tune making 480 to the ground with his cobra. Know another guy with a Kenny bell on it making 620 to the wheels.
Justin
Justin
Car: 89 Iroc-z
Transmission: TH400
I'd tyake the TTA over the cobra in a sec. Whats the Cobra .2 faster and thats comparing a Supercharged V8 to a turbo V6
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Nice video, especially the last one.
Give me a bone stock TTA, a paperclip, crescent wrench and fill at the gas station of my choice and I'll hand a bone stock 03/04 Cobra its a$$
Just as long as Evan Smith isn't driving it.
Car: 89 Iroc-z
Transmission: TH400
Can you brake boost in a manual car though?
from a roll, you just hit brake and gas at the same time
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Stock drag test attached, pair of 13.6s. That's faster than most magazine runs for LS1 Fbodies... :
Car: 2018 Camaro SS
I've seen stock TTA's run faster than that..is EVERY ONE a low 13 second car? No, they're turbo cars..they're like women. Everything could be fine one minute and BAM! The next minute it doesn't do what you want it to and before you know it you're sleeping in the garage...
Ughh, off topic..
Car: 89 Iroc-z
Transmission: TH400
trap speeds of 101-102 isnt really enough to go low low 13's on street tires and stock converter. but i guess there are some that have hit higher than that, so i dont doubt a low 13 is possible. it took full bolt ons for my buddies L98 89 formy to run 13.6's at 100-101.
Even when I maxxed out all the stock stuff, I still only ran 12.1@111. And here's how much a good launch does for a TTA. The 12.1 run was done on Nittos with a 1.69 short time. With my Firestone Firehawks, it was 12.6@111 on a 1.85 short. Nothing other than tires was changed.
Car: 2018 Camaro SS
Car: 89 Iroc-z
Transmission: TH400
you gained alot of time on those drag radials. thats what TPI and LC2 cars need.
i'm just saying that stock street tired, stock stalled TPI and LC2 cars wont beable to launch at 100% which is needed to run those great ET's for the trap speed
No offense dude but you talk out your *** so much. It's all about the launch on those cars. If you can launch with boost and hook and keep the converter locked you can do it all day long.
i know the launch is what makes these cars. i see my top end drop off after second gear. i know there is a .3 second difference from a 2.0 60 and 1.88. i have seen .1 gains on icing the plenum and runners for colder air... i seen how weather effects the car. from hot days to cool nights, summer spring and fall.
problem is that on stock tires its gonna be VERY difficult to really get the best out of those cars, LC2's and L98s. just like TTA said, tire change netted .5 seconds for him. i'm just saying with a car that traps 102mph, its gonna take good tires to get good ETs such as the low 13s many claim.
I dont doubt stock TTA could hit lower 13's on drag radials/slicks. but bone stock its gonna take a great track prep to hook and go lower 13s. mid 13's is all i would think they can go. sure every car type has their fast freaks from really goood drivers. but majority of the cars driven by decent drivers on stock tires will only go mid high 13's
Can't really compare launching a TPI car against a TTA. The TTA will out launch any stock TPI car. The torque arm mount does that. The TTA mount is relocated and isn't on the trans like V8 cars.
Its very easy to get 1.9x short times in the TTA, let alone 1.8x. All on street tires with the stock converter. I was able to run 1.6x on the stock converter and drag radials. Heck, I didn't change my converter until I was running 11.8x because it was killing me. 11.8@121 isn't too good
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Car: 2018 Camaro SS
Originally Posted by mw66nova
do you have any pics of the torque arm mount?
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
My best friend has an 86Gn stock it ran 13.9.I used to smoke the hell out of him with my zz4. Lets just say it now smokes the crap out of my zz4 with just a few mods.If you know how to work on those turbo 3.8s 11s is very easy with the stock turbo.I don't know much about those types of motors. I think the fastest ones ran low 13s in a TA but I could be wrong.Please correct.With a few mods the TA could run easy 12s but stock for stock the cobra.By friends dyno 232hp at the wheels and It was pretty much stock at that point. Just shows you how under rated those figures are.
As said, stock for stock, the Cobra has it all over a TTA. That's reality
Here's a quick hit on mods for when I ran 12.1@111 on a 1.69 short time:
ATR MAF pipe, 8" K&N, 1 screen out of MAF, LT1 valve springs, 160 thermostat, adjustable fuel pressure regulator, adjustable wastegate, cat pipe, Thrasher92 chip, and Nitto Drag Radials. Everything else was completely stock. 93 octane with Xylene mix yielding about 99 octane. 18psi of boost with 0.0 KR
Dynoed the same weekend of that run:
318/455 to the wheels
Really doesn't take much
But this combo was maxxed out on pump gas, at least the stock injectors. Could have broken into the 11's easily with a race chip and race gas. But I always ran a street chip and never put any race gas in.
But this combo was maxxed out on pump gas, at least the stock injectors. Could have broken into the 11's easily with a race chip and race gas. But I always ran a street chip and never put any race gas in. Thread Starter
Car: 1991 Z28
Engine: 5.7 TPI L98
you did less mods to get your TTA in the low 12's then i did to get my L98 into the mid 13's...
Here's a new question for this post. What car will be worth more 10 years from now, in the same condition and mileage? There were alot more than 1500 03-04 Cobras made.. i bet a TTA in primo condition will get 35 grand...
Car: 89 Iroc-z
Transmission: TH400
yep, all those motors were underated. they say 250hp... but its closer to 285 on motor by those rwhp numbers. good L98s dyno 215-220rwhp and are rated at 230-240hp crank. LOL L98 is more like 260-265hp from the factory.
The TTA was making ~300hp to its rated 250hp
Those 3.8 turbo motors are crazy! I really like the motors. Which they put them in my monte.But then I think about the good old american small block v8 that I love.A lot of the GN guys crack jokes about the montes but it is like comparing apples to oranges.
